need help plz
Old Apr 6, 2006 | 06:14 PM
scort_si's Avatar
scort_si
Default need help plz
the pipe on my back box that joins the middle section has snaped from the box
the help i need is there an easy way to pull the pipe of tried wd40 hammer and flat end
screwdriver but cant seem to get the back box pipe off,cant take to my local garage because
ive tried 3 and they say they only suply and fit there own goods so need to get this pipe off
asap!!!
Old Apr 6, 2006 | 06:52 PM
scort_si's Avatar
scort_si
ANY 1 ?
Old Apr 6, 2006 | 07:06 PM
Boris357's Avatar
Boris357
Angle grind down the side of the pipe and then bend it off?
Old Apr 6, 2006 | 07:19 PM
scort_si's Avatar
scort_si
cheers mate but should of said i only have ,basic tools like socket set ,hammer,screwdriver set ,
someone mention about a blow tourch ,but if i drove round in it for a while would that heat it up or do any thing to get it off???
Old Apr 6, 2006 | 07:22 PM
Boris357's Avatar
Boris357
Im not sure how hot the exhaust gets further down the pipe, if its not enough all you might you do is just expand it
Must be somewhere that would let you use an angle grinder for 5 minutes any friendly bodyshops?
Old Apr 6, 2006 | 07:26 PM
ballin's Avatar
ballin
they are stubborn as fuck mate, all you can do is keep smacking shite outta it, will come off in the end
Old Apr 6, 2006 | 08:26 PM
scort_si's Avatar
scort_si
troulbe is the middle section is a few months old so didnt think it
would be that hard to come off dont kno y the other owner befor me didnt do the whole thing
rsturbo27
Sep 1, 2015 09:54 PM
niallturbo
Dec 21, 2004 08:14 PM
cossieanth
Nov 21, 2004 06:54 PM
11
Mar 13, 2004 09:11 AM
28
Dec 10, 2003 07:46 PM
