air injectors
say if you was running a twin turbo set up would you have to
used two sets of air injectors,and can these be used on w/gates
and down shoot me down guys just trying to find some info out
You could use 1 common injector to regulate 2 turbos with 2 Y pieces.
However if 1 turbo starts to fail and reduces its boost output, this will cause the other turbo to be over worked as the injector will compensate (if closed loop). Also it could be difficult to match the 2 turbos outputs. For them to be matched properly you would need each turbo to feed a seperate inlet manifold/plenum each and then control boost pressure outputs from each with 2 air to air injectors.
If your ECU has the facility to monitor turbine/compressor wheel speed then you could also control it that way.
mk3ste
Oct 17, 2021 10:09 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
stand still you little fucker
