s2 died on me
Old Apr 6, 2006 | 04:26 AM
johnnvs's Avatar
johnnvs
Default s2 died on me
i was giving my car a little blast last night on the m-way got it up to about 140 fine when i slowed down and come of the m-way it started juddering like it was running out of fuel then just died. Wouldnt start but then after about 5 mins turned the key and started fine. I think it could be something to do with fuel it was pretty low on fuel when this happened, any ideas?
Old Apr 6, 2006 | 07:51 AM
Ezzy Danny's Avatar
Ezzy Danny
When engines are doing 140mph they tend to get very HOT would say that would have something to do with it. Also fuel being low is never good. Fill up, check ya oil and water and make sure the engine has been setup and treat it to some new spark plugs lol
If its running okay now would say it just over heated.
Old Apr 6, 2006 | 10:37 AM
COSSIE 1's Avatar
COSSIE 1
fuel starvation if u were low??
Old Apr 6, 2006 | 10:58 AM
jezRS's Avatar
jezRS
2nd'd
my fuel gauge goes down just as fast as my speedo goes up
Old Apr 6, 2006 | 11:46 AM
SafeChav's Avatar
SafeChav
Failing the above my 2nd guess would be the sensor in the distributor breaking down.
Old Apr 6, 2006 | 12:55 PM
AndyRST's Avatar
AndyRST
imagine the damage to the turbo with it being red hot and then the engine stalling due to possible low fuel in the tank
Look after your S2 and it will look after you
Old Apr 6, 2006 | 02:40 PM
GrimmeRS2K's Avatar
GrimmeRS2K
most rst fuel pumps if not changed are proberly had it even if they sound ok, could be fuel related or as above your dizzy is on the way out.
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
