REMOVING TURBO ON S2ERST??
Old Apr 4, 2006 | 07:13 PM
COSSIE 1's Avatar
COSSIE 1
Default REMOVING TURBO ON S2ERST??
How difficult is it to remove and refit a t3 turbo on a s2erst?? bearing in mind ill be taking it off with the manifold still attached to the turbo , cheers all
Old Apr 4, 2006 | 10:08 PM
cossie350's Avatar
cossie350
Easy mate, i got a t3 on my fiesta, alot less room and its still not too bad
Old Apr 4, 2006 | 10:18 PM
HORNETS7's Avatar
HORNETS7
just watch your radiator !!!!!!
Old Apr 4, 2006 | 10:19 PM
yzfr1boy's Avatar
yzfr1boy
yer a tip for free ,i took mine off other week and couldnt get it out from the top so i supported the engine on a trolley jack and took the top engine mount out , bolt on top n 1 in inner wing, and pushed engine back as far as possible came straight out hope this helps
Old Apr 24, 2006 | 06:19 PM
white cab's Avatar
white cab
take the front bumper off and pop the radiator out if you want to do it properly.
if not you can get it out from the top just be carefull you will damage the rad possibly is a bit tricky
Old Apr 25, 2006 | 10:25 AM
s2_rsturbo's Avatar
s2_rsturbo
Piece of P***
cossie350
I know what its like. Bit of a long'en
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
kevin36
Aug 14, 2015 08:36 AM
