REMOVING TURBO..S2ERST...
Old Apr 4, 2006 | 07:10 PM
COSSIE 1's Avatar
COSSIE 1
Default REMOVING TURBO..S2ERST...
im changing my turbo soon and as soon as my backs feeling better im gona attempt to take of my T3 from my s2erst and wack my lovely stage 3 T3 hybrid turbo on , now the question im taking the turbo off with the manifold and actuator still attached to make it easier has anybody got any pointers on how to tackle it and how difficult is it??? , cheers all
Old Apr 4, 2006 | 08:14 PM
ballin's Avatar
ballin
i took just the turbo off when i did mine, piece piss
Old Apr 4, 2006 | 08:29 PM
Keith B's Avatar
Keith B
If you take it off with the manifold still attached watch out for the rad - Pulling it off the studs in the block brings in perilously close to the fragile rad fins.
Old Apr 4, 2006 | 08:33 PM
Doug's Avatar
Doug
As Keith says And tape a piece of cardboard up against your rad,
And to make the job even easier remove the thermostat housing slides out a lot lot easier
Old Apr 4, 2006 | 10:00 PM
Wazzzer's Avatar
Wazzzer
Yep I fooked a rad doing mine, be careful or just take it out to be really safe, makes it a lot easier to pull the turbo out
Old Apr 5, 2006 | 11:01 AM
COSSIE 1's Avatar
COSSIE 1
are all the bolts easy to get to, to undo etc?
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
