are rear shocks ie konis the same 4x4 and 2wd
Old Apr 4, 2006 | 06:42 PM
cossiecrew's Avatar
cossiecrew
Default are rear shocks ie konis the same 4x4 and 2wd
i know the fronts are different but what about the rears ?
Old Apr 4, 2006 | 06:44 PM
seveneigths's Avatar
seveneigths
Default Re: are rear shocks ie konis the same 4x4 and 2wd
Rears are the same fronts are not, i think there is a 2mm differance in the fronts for the extra weight
Old Apr 4, 2006 | 06:48 PM
cossiecrew's Avatar
cossiecrew
cheers mate
Old Apr 4, 2006 | 06:51 PM
Eagle's Avatar
Eagle
Super Moderator
4x4 fronts have a larger diameter bit for clamping into the hubs .. rears are the same tho
FlashRS
Sep 14, 2015 12:36 PM
FlashRS
13
Aug 31, 2015 06:02 PM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
