Brake Experts - FTAO M. Rainbird etc...
Could you offer me some advice on the following after I have clocked various parts of my front brakes/hubs etc... To try and sort my warping problem
Nearside inner surface of disc:
Middle of disc: 5.5thou
Inner edge of disc: 5.5 thou
Outer edge of disc: 3 thou
Nearside outer surface of disc:
Middle of disc: 7 thou
Inner edge of disc: 7.5 thou
Outer edge of disc: 8 thou
Offside inner surface of disc:
Middle of disc: 6.5 thou
Inner edge of disc: 11 thou
Outer edge of disc: 6.5 thou
Offside outer surface of disc:
Middle of disc: 5 thou
The hubs have already been skimmed in the past:
Nearside hub:
Inside edge: 4 thou
Outsdie edge: 4 thou
Offside hub:
Inside edge: 2.5 thou
Outsdie edge: 3.5 thou
What is the minimum thickness I should go down to on a originally 32mm thick disc?
o/s disc - 31.35mm
n/s 30.7mm
I haven't managed to clock the bells yet but I will do if I need to?
Thanks
Nearside hub:
Inside edge: 4 thou
Offside hub:
o/s disc - 31.35mm
n/s 30.7mm
Thanks
DavidK
Sep 27, 2015 02:55 PM
