Turbo coolers for S1
Old Apr 4, 2006 | 05:23 PM
daveyboyreeves's Avatar
daveyboyreeves
Default Turbo coolers for S1
Anyone know of where to get a turbo cooler for a series 1 from?
Is it needed? I know the s1's had air cooled turbo's as standard. I'm want ing to run 20 psi ish through a 2.1zvh.
Any help appreciated.
Dave.
Old Apr 4, 2006 | 05:25 PM
Oranoco's Avatar
Oranoco
20psi through a 2.1 ZVH will be a handfull . You will need a much larger capacity front mount to let you get away with that. GRS intercoolers come very highly recomended but you may need to do some trimming of metalwork to get it in there
Old Apr 4, 2006 | 05:32 PM
daveyboyreeves
Nothings set in stone. I've got a proalloy front mount intercooler was just wondering if i needed a 'turbo cooler' as in water.
Cheers.
Old Apr 4, 2006 | 05:56 PM
Oranoco's Avatar
Oranoco
I don't run one and I'm at 25psi and use my car on track. The only extra I really want is an alloy rad as after 3 laps at full chat the water temps get very high
Old Apr 4, 2006 | 06:01 PM
daveyboyreeves
Isn't your motor a s2? If so hasnt your turbo got a water feed from your rad? the s1's didnt have this as they where air cooled.
Dave.
Old Apr 4, 2006 | 06:20 PM
Oranoco's Avatar
Oranoco
The S1 is indeed not water cooled but they had a slightly larger oilway to help facilitate cooling. If you're planning on running 20psi I'm assuming you have a hybrid? Providing you do and you have th eright one it will be fine
Old Apr 4, 2006 | 06:33 PM
daveyboyreeves
Thats just it... i dont have my turbo yet. I will be purchasing a new one shortly. I just wanted to know if it needed to be water cooled and if i needed a turbo cooler as well.
Old Apr 4, 2006 | 06:39 PM
Oranoco's Avatar
Oranoco
If you buy a hybrid S1 turbo then no it won't need water cooling. If you haven't got the turbo yet you will be best off discussing what you want with th eturbo supplier and tell them what you want and see what advise they can offer
Old Apr 4, 2006 | 06:45 PM
daveyboyreeves
Will do.
Cheers.
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
StephTell
Sep 2, 2015 06:31 PM
