idle speed
Old Apr 4, 2006 | 05:19 PM
royRS's Avatar
royRS
Default idle speed
my saphire 4x4 cosworth (green top) runs at idle to slow ,i know their a screw under de trotle body to adjust this but before i turn the screw have i disconnect the connector of the little motor on the trotle body that does the idle speed ( dont now the name in englisch) or is their an other way to adjust the idle speed thanks
Old Apr 4, 2006 | 05:29 PM
rapidcossie's Avatar
rapidcossie
get it up to temp and disconnect the idle speed valve.
use the screw on the throttle to set revs to about 1k and lock it again.
connect idle valve and hey presto
Old Apr 4, 2006 | 09:08 PM
royRS's Avatar
royRS
THNX M8
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
routemaster
Sep 7, 2015 05:27 PM
