GETTING SHINE BACK ON REAR LIGHTS??..
Ive got a set if tinted lights on the rear of my s2erst not the spray on stuff but the proper red/black tinted ones thing is they arent very shinny compared to some any ideas how i can get a nice shinny finish i was thinking a layer of laquer can this be done??? cheers all
From: learnin to build a yb lump properly in dennis's garage
it can be done but u best be pretty goosd with a rattle can as it will run easily lacquer them then give em a bit of a rub with t cut should broing back the shine
the only problem with laquer is getting it to stick to the plastic lights and not peel off in no time, i would give the lights a real good clean in soapy water or somin, air dry, then give them a DUST coat of clear plastic primer, or adhesion promoter first, then two or three light coats of laquer, and finish with a polish.
Originally Posted by charlie luciano
Another good one is silicone spray
C L
C L
sridgett
15
Aug 3, 2015 07:26 PM
