Bit of help needed with Sierra cos 3dr elec radio aerial
My 3dr has the original electric aerial which has always fully extended & retracted as it should, i haven't switched the stereo on for months & went to use the stereo yesterday as it was a long journey & the middle 2 sections of the aerial won't extend anymore so the reception is a bit poor.
Is the aerial knackered or is their anything i can check.
Thanks Simon.
Thanks Simon.
Simon
I had the same problem with mine when I had a 3dr.
I would turn the radio on until the ariel extended as much as it could then get a cloth and spray some WD40 on it.
I would then wipe the ariel with it.
Repeat a few times and the ariel should start to work normally.
This always worked for me and didn't seem to do any harm.
Thanks
Terry
Thanks
Terry
Managed to get one part free but theirs one more bit to free off before it fully extends to how it should. Think i'll have to remove aerial & dismantle to do it properly.
Does the square looking plastic trim panel that covers the elec aerial motor just pop off or do i need to unscrew the whole interior side trim panel in the boot to remove the aerial ?
Simon.
Simon.
