whats the best brake setup on a 4wd saff????
Passionford Thread Killer
Hay kids, I what some good stoppers for my saff, but Don't really wanna spend AP,Willwood,ect prices. Do you really need huge calipers for fast road use? My cars 350-60bhp. any input would be handy, cheers.
350 horsies on mine, and i have the following
Front - 330x32mm rotors that are being clamped by a pair of Focus RS Brembos
Rear - 300x32mm R&B big disc kit, being clamped by standard rear caliper
car stops on a sixpence
Graceland
Cool, where did you get the brembos from and did you have to use a bracket for em? Is R&B mike rainbirds place yeah?No abs then and standard cossie hoses?
I aquired the brembo's from Slowpoke on here - and made the brackets myself
R&B is rainbums place yep, no abs and goodridge hoses, but left the valve block and other gubbins there
excellent stopping power, but i rekkon with some hotter pads it will stop quicker from higer speeds
Originally Posted by loader5710
thanks alot that sounds like the set up Im after, any idea I should pay for calipers?
but expect to pay upwards of Ł200 normally
Originally Posted by slowpoke
why no ABS ?
just curious
just curious
Originally Posted by Batfink
Graceland
Off topic here mate
Your car looks the bollocks in Fast Ford
Off topic here mate
Back to the point
www.compbrake.co.uk very cheap and the calapers are just 3LB each the owner knows his stuff
Originally Posted by Graceland
matt - no abs as i don't like foot massages every 5 mins when braking hard
Neil.
DAN P
is that the guy who was nat combe the other week, had a deer jump out at him
?did he have the comp 6 pots?
?did he have the comp 6 pots?I use 330mm 4 pots from Comp brake on front, and 300mm big discs with standard calipers on the back.
Front pads are Hawk, rear are DS2500 - bloody ace pads.
The car stops like nothing else I've been in. They do not cost AP money and they DO work as well as APs IMHO
I also don't run ABS on track, as it is too over sensitive - it works well, but comes in too soon for track use.
On the road or in the rain the ABS is always on!
The deer incident was at the Ring, and I was at Coombe the other day too!
Simon
Incidentally rear big discs / bells & rotors are also by Compbrake.
PM me if you want a set as I may be able to get a good price (had a fair few bits off them now)
Simon
Simon
SiB
cheers mate but i just got focus RS calipers and 330mm disc getup thanks for the help though
. Actually you might know , whens the next track day at coombe?
Originally Posted by RS500/104
Back to the point
can I just use focus rs discs or do i need ally bell thingys, do they sit on the saff hub ok I mean? :top:
I use 378x32mm discs with Porsche GT2 6-pot calipers up front on my 4x4, and 330x20mm discs at the rear with standard caliper. A question: How do you fit a disc that`s 32mm thich at the rear with a standard caliper?
. So why would it come off then???
