Engine Experts - V6 Question...
Old Apr 3, 2006 | 12:57 PM
Malc50's Avatar
Malc50
Default Engine Experts - V6 Question...
Hi Guys
Snapping con rods, is this a normal problem when tuning a Mondeo V6?
The conrod that snapped was the middle rod in the front which I think is
called number 4. This snapped in a 97 car and in an 01 car.
Same flowed heads were on both cars, not skimmed.
BHP is approx 30 up on standard .
Any help or pointers would be gratefully recieved
Cheers Malc
Old Apr 3, 2006 | 01:01 PM
Well if it happened twice to you, it sounds like a common problem!
Rods only normally break due to either excessive det or excessive rpm IME, flowing the head(s) on an engine and keeping the same rev limiter is unliklely to cuase a problem.
Old Apr 3, 2006 | 01:28 PM
Malc50's Avatar
Malc50
Hi Chip..
I think he has changed the cam shafts, maybe the timing out and its suffering det.... It is a tough one I thought on a N/A engine you would really have to go some to snap a con rod....
Malc
Old Apr 3, 2006 | 01:42 PM
richm's Avatar
richm
on a NA engine, rods will almost always break whilst in tension (ie excessive rpm as Chip says, at the top of the exhaust stroke), in fact it's often the bolts that break first, or round the cap..
I've never seen a rod break in compression direction in a NA engine, (maybe with huge boost forced induction/NOS...)
looking at the remains of the rod should give you a clue what happened and where it broke
Old Apr 3, 2006 | 02:20 PM
RichM, I agree totally.
The number of arguments ive had with people telling them they dont need to change rod bolts due to adding nitrous etc is silly.
People just dont seem to be able to seperate the cylces out in their mind and realise that rod bolts are typically under less strain if anything not more when used on a nitrous engine! (unless you use nitrous to extend the RPM range of the engine by forcing it to breathe somewhere it couldnt before of course!)
Old Apr 3, 2006 | 09:47 PM
Malc50's Avatar
Malc50
Hi Guys
Thks for the responces, What tuning companies would know this engine inside out??
Cheers Malc
Old Apr 4, 2006 | 01:00 PM
Malc50's Avatar
Malc50
Up for the day guys please
Cheers Malc
Old Apr 4, 2006 | 01:17 PM
windrain's Avatar
windrain
Engine was be running a little lean because of bigger throttle body and filter. Would this have any effect?
Old Apr 4, 2006 | 01:18 PM
windrain's Avatar
windrain
Camshafts were the standard.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
Mark Mawson
Aug 31, 2015 07:09 PM
