What can i use to clean HT leads?
OK, ive had some oil leak issues of oil leaking into the plug holes.
niow thats resolved (yay!) but my HT leads are still full of oil
is there anything i can do totry and get this oil out? at the moment i'm getting a misfire which im pretty sure is related to them being mingin.
i dont want em to LOOK nice, i just want em to work...
i found some stuff called "HOLTS DAMP START IGNITION SEALER" so io sprayed em full of that
then i red the side and ralised what it was
its probabloy gonna do a worse job than the oil
A bundle of pipe cleaners used carefully, a tampon
I guess 'it does what it says on the tin' won't help your mood much? It tends to flake off, so you may be able to get it up and running until you get new leads?
? I guess 'it does what it says on the tin' won't help your mood much? It tends to flake off, so you may be able to get it up and running until you get new leads?
The Youth.
Sep 30, 2015 09:59 PM
cheers lads
