24v people
is anyone running aircon on there conversions
im contemplating on keeping the aircon on mine but came to a problem
just in the middle of taking the old management out and noticed that the plugs for the aircon are joined in with the loom
also same on 24v loom except i disgarded it on this loom lol
what i want to know is , is the aircon ecu controlled?
can i just unpick my aircon loom out and just use it as a seperate loom just for this
thanks for any advice
the aircon is linkd to the ECU because it does funny things like raise the idle speed when you turn it on etc. etc. you should be able to keep it seperate and have it still work tho, and just connect up the few wires you need to the ECU
dam lol
ive still got another 24v loom here with it all connected still so will take a look at that nxt then
just going to take the dash out my car now and pull the engine loom out so will have a better verdict on it worse case no aircon
thanks
thanks
The only one I have seen working was one done by topboss for a Guy on interford. I know the guy who wired it up, and I don't know the details but it took all day. I think he had to make a new loom and relays.
well im making a new engine loom sort of
i will look into the aircon loom if its the same connectors as my sierra that go onto the airbox i will use the 24v if not then i will have a look into it
Generally speaking, Air con is disabled by ECU at start up and Wide Open Throttle, via a relay.
Also as said revs are usually increased in preparation for the extra load.
Also ECU will bring on Condenser / Rad fan /s and leave them/ it on after switch off to cool the Condenser.
I found that on my Focus the ECU also disables Front / rear heated screens and heater and A /C at start up.
I just traced the wiring back to a relay and put an ordinary ignition feed to it.
I'm not using A/C but wanted all other heating.
My V8 ECU has A/c signals that I could have used.
well ive just gone through the loom
started with the wires for the air con
what a disater
the cars not going to have aircon now as ive completely lost myself
ive found the relay so traced wires form relay
goes to another relay which also has the battery light going to it aswell
i may give it another go in the morning as im a bit tired but dont think its going to happen
also my heater controls for the fan i know there in the main loom but the aircon plug in near the switch ive unplugged it will myheater still work?
i carnt see it not tbh
what a disater
there's a thread with wiring diagrams in the tec help forum that may be of use to you
https://passionford.com/forum/viewtopic.php?t=184051
i just thought that the wiring is pretty similar on all cars with air con, and would help you to trace things as they all operate in the same way with the icing switch, pressure sensor etc
Originally Posted by xr4x4rs
i dont know mate
to be honest i have no idea how a aircon system works
i was just hoping that it was a seperate loom but its not
the air con is a seperate loom, but it's also plugged into the main loom for various points of reference
the air con loom is not a stand alone loom though as it's wired into the main loom
you will need the wires for the heater controls mainly and then follw them back, keep everyting you need that is connected to the air con from the car and dispose of the rest
it's not the end of the world but it is a pain in the arse, the ecu needs to get 2 sets of feed from the ac loom though, the one where it turns it off when you are cranking and under wide open throttle and also a feed from it to raise the idle when it's on
the idle thing you can probably get away with by tricking the ecu into thinking the heated screen is on, the others though might be easier if you just forgot about them and turned it off when you were booting it or ran it through the engine running relay
i did the same thing on mine before i realised i need to lose the ac to get the turbos in there
dojj
my heaater wires are still connected this is in the main car loom as you have said
my aircon loom is built into the management side of it 2.0 dohc engine
now im fitting a 24v i was wondering if i couyld keep the aircon as ive never had a car with air con and though it would be a nice touch
the aircon loom does plu into another connector that comes off the heater controls
i went through the loom last nite but just got totally lost so by the looks of things its not having it
unless i can use the one out of the 24v engine loom
there are 2 questions you need to answer
the first is "does the car you are planning to the the 24V lump into already have air con?"
if the anwer to this is no then you can't fit air con to that car without serious remodicitation of the bulkhead as the air con bit that sits there is significantly bigger than just the heater motor
the second question is "you already have air con so you need to splice the air con loom from the car you have into the loom that you want to build into it"
this is a bit more difficult BUT at the same time, easier
you already have the loom for the air con from one car, you just follow it along with the loo for he other car (the 24V) and use the same places to intersect it
this is a LOT easier than it sounds though but we are talking of only 4 wires tops really
you already have the idle booster so all you need to find is where it links into the 24V loom and where it links into the original loom and you have one sorted
the second is where the cut out is for cranking/wot
again, find the source wires for this on the original loom and on the 24V and sorted
my car does have aircon
so i do have the loom ive already tried tracing it through but it just goes everywhere lol
ill give it another go later and se what i can do i doubt i can sort it now tbh
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
