need a little help with an YB engine
Old Apr 1, 2006 | 09:40 AM
wimwerf's Avatar
wimwerf
Default need a little help with an YB engine
hello.....
a friend of mine has a problem with his current YB engine....it has a big crack in bore number 3...so the 205 engine (block)is exit....
he wants to buy a 200 block now....
question...is the crank, rods from the 205 usable in the 200 without problem...
what about the pistons (2wd ones)....because the current ones had done only 6000miles...are they usable in a 200 block with a 2wd head?...
what about the oilpump etc etc...
thanks for the help....
Old Apr 1, 2006 | 09:53 AM
PAUL S's Avatar
PAUL S
a 200 block is a direct replacement for a 205 - the internal dimensions are all the same
Old Apr 1, 2006 | 11:17 AM
wimwerf's Avatar
wimwerf
up....
Old Apr 1, 2006 | 11:25 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
As above m8, all internals are a straight swap, I think the only diff between the pistons is the 4wd has the offset pin to eliminate piston slap
Old Apr 1, 2006 | 11:52 AM
Stu @ M Developments's Avatar
PassionFords Creator
Direct swop, identical.
Old Apr 1, 2006 | 12:27 PM
wimwerf's Avatar
wimwerf
but what about the compression ratio....he wants to use 2wd pistons in a 200 block with a 2wd head.......
compression ratio same..higher..lower..or?
Old Apr 1, 2006 | 12:55 PM
same compresion as the 205 was.
Old Apr 1, 2006 | 01:18 PM
wimwerf's Avatar
wimwerf
thanks all....
Old Apr 1, 2006 | 01:22 PM
Oh, should have said, assuming his block hadnt been decked of course!
Measure the height from the bearing tunnel to the block face is only way of telling!
But thats the same as using another 205 block
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
