Alternator 2wd and Escort Cosworth
Old Mar 30, 2006 | 07:22 PM
SPADGE's Avatar
SPADGE
The 2wd one will be fine once you put the other pulley on it mate
Old Mar 30, 2006 | 09:58 PM
fatboyz's Avatar
fatboyz
Default Re: Alternator 2wd and Escort Cosworth
Originally Posted by YUM360
Need a alternator for wed's dyno
Was going to use ranj's one out of his car but my one failed the other day. So now its bolted inside YUM. Have got a brice unit so passed it on to mark but have found out it not the correct one for a escort cossie. Have found a alternator of a 2wd is it the same as a escort one apart fron wheel?
I dont want to take the one of yum just for wed dyno
So does anyone know?? or has a spare escort cossie alternator that dont work but spins ok
Thanks
Dave
hi dave i have a 4wd one and i need a 2wd one but im in bristol did you want to swap over the pulleys or do you have it sorted cheers dave
Old Mar 31, 2006 | 02:11 AM
Gav Diamond's Avatar
Gav Diamond
Im sure that a 2wd and 4wd ones are different in the way they bolt to the gearbox
Ie: one has threaded holes and the other doesn't other than that i don't know
Old Mar 31, 2006 | 03:08 AM
boost mad's Avatar
boost mad
alternator mate, not startermotor
Old Apr 1, 2006 | 03:51 AM
Gav Diamond
This is how awake i am when i get home from work at 4am
Vincereese
Jun 1, 2023 09:14 AM
turbotrev
Aug 22, 2015 11:41 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
