Question for a sparky! Out side power.
Installaing an outside device. Have a spur on the inside of shed.
IN regards to the outside cabling which will be permanent and exposed to all weather Which sort of cable do I need? Wont be going underground but will go on some cable tray and can termainate onto a transformer in an IP rated weather proof box to power an outside Wireless Access Point.
Armoured is the easiest and best stuff for this sort of job. Providing it is not getting stood on or driven over it will last for years, even in the elements. Does'nt need to buried either as long as it's out of the way of potential damage.
