Fan switch plug and contacts
Originally Posted by rizla
Is it for the 3 Door ?
I just bought a plug for my big turbo Escos the other day in Fords
Ł10,70
Ł10,70PassionFord Post Whore!!
Are you on about fan switch or the plug that plugs to it.
If you on about switch I've just bought one for a 3dr from ford.
Part number = F7001614
Fibre washer to go with above = F6005731
escos plugs are differant to sierra ones, you can still get the sierra ones, theres a differant finnis number for them, its a blue plug with a small bit of loom on it, i have 1 in stock at work.
i'll get the finnis number tomorrow.
Cheers for the help
I found an old one in my vast stack of spares and managed to use the pins and solder some new wires into place and usemy original body so all is good
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
