is this possible
Old Mar 29, 2006 | 07:04 PM
Fiestamatt's Avatar
Fiestamatt
Default is this possible
right ive had no end of trouble with my fuel pump,
ive replaced the pump (still doesnt work)
ive replaced the spades on the pump(still doesnt work)
is there anything to stop me rewiring the fuel pump using a relay and a live feed from the ignition. so its running standalone.
Matt
Old Mar 29, 2006 | 09:28 PM
rst in breaking's Avatar
rst in breaking
not that i can think of as it would still be run off the ignition, have you tested the pump using a live stright to it from the battery?
Old Mar 29, 2006 | 10:30 PM
xr-stu's Avatar
xr-stu
you checked the inertia switch mate? sits down on the A pillar behind the little cover in the passenger side footwell, theres sometimes a hole in the cover you can reset it through. worth checking!
if not then yeah you can wire it like you said, ive wired mine like that in my zetec conversion.
you want a normal switching relay with the switchable live coming from the igntiion, then you need to wire the earth from the relay into the earth that goes into the ecu. if you look at the engine loom, between the engine and ECU there will be a bunch of 7 wires that come away from the main engine loom and plug into the car loom, the brown wire in this group is the one you want!
make sure you fuse it properly and wire it in through the inertia switch!
Old Mar 30, 2006 | 04:41 PM
Fiestamatt's Avatar
Fiestamatt
thanks guys, gonna get on it this weekend :-D
Old Mar 30, 2006 | 05:42 PM
m4frd's Avatar
m4frd
just make sure that when you turn the ignition off the live feed cuts of too
Old Mar 30, 2006 | 09:54 PM
xr-stu's Avatar
xr-stu
if you wire the live for the relay in fromthe ignition, whenever you turn off that live the relay will 'turn off'
Old Mar 31, 2006 | 09:21 PM
sy16v's Avatar
sy16v
Matt is this the cossie fuel pump you were buying or your frst one
Old Mar 31, 2006 | 09:41 PM
Fiestamatt's Avatar
Fiestamatt
just got the standard 1 on for now, gonna uprate it to a cossie 1 or systec very soon.
Matt
Old Apr 1, 2006 | 09:18 AM
Sean_RS's Avatar
Sean_RS
try a connection straight to the fuel pump... i had a similar prob... it was the little black box in the fuel tank that 2 wires go in to, them come out of and connects to the pump...
Old Apr 1, 2006 | 12:19 PM
Scottish Greg's Avatar
Scottish Greg
If you have only changed the pump, i would guess its the "black box" Sean spoke about.
I changed my pump and have now bypassed that little box, as its only a signal suppression unit and will not affect safety.
Old Apr 2, 2006 | 12:17 PM
Fiestamatt's Avatar
Fiestamatt
so far so good, as far as im aware the problem has gone, hopfully can concentrate my disposable income on tuning now lol.
Thanks for all your help peeps, D:
