Lambda sensor connections ???
Old Mar 29, 2006 | 11:53 AM
2wd's Avatar
2wd
Default Lambda sensor connections ???
Hi Does anyone know witch wire is what on a 3 wire Lambda sensor for a 4wd Sapphire Cosworth ??? ( earth, live and sensor output).
Red ?
White ?
Black ?
Old Mar 29, 2006 | 12:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
normally,
Black Ref. (out)
Red Ref. (in) & Heater (+)
White Heater (-)
taken from
http://www.lambdasensor.com/main/mcolours1.htm
Old Apr 4, 2006 | 12:25 PM
2wd's Avatar
2wd
thanks
Old Apr 4, 2006 | 02:25 PM
Dave Henshall's Avatar
Dave Henshall
the above is 100% correct, thats where i got my replacement sensor from, a 12mm 3 wire titania which was checked against stus wideband sensor and was just as accurate as the original ford ones which are literally £100 more expensive
Old Apr 4, 2006 | 03:31 PM
2wd's Avatar
2wd
super...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
