cossie wont spark ??????????????
Old Mar 27, 2006 | 09:26 PM
lisa 23's Avatar
lisa 23
Default cossie wont spark ??????????????
cossie problems again i put a post on here yesterday saying my cossie wont start fuels and sparks but wont start up im now thinking the problem was a weak spark as this was very light yellow spark before and (now it wont spark at all ive changed coil, crank sensor, and leads, new plugs, and tried another ingition amplifier anyone got any ideas
Old Mar 27, 2006 | 10:14 PM
cossie604's Avatar
cossie604
phase sensor?? They are quite common, the insulation breaks down on them thru age.
Old Mar 28, 2006 | 10:20 AM
Dave Henshall's Avatar
Dave Henshall
also battery voltage,
ive had it where the battery is man enough to crank and crank and crank the engine but get now spark,
a set of jump leads and away it went, turned out my battery had a dud cell
Old Mar 28, 2006 | 11:27 AM
Avinitlarge's Avatar
Avinitlarge
Thought the phase sensor only created a pulse for the injectors and the crank sensor for the spark.
Anyway....
My mates cossie had a similar problem, I spent hours on it, New coil, crank sensor, phase sensor, leads, Ecu. In the end he just bought another loom. His was bodged up proper. I dont know if the loom cured his problem, I just lost interest in the end, My mate wouldnt lisen to my thoughts and wanted me to test everything
Old Mar 28, 2006 | 08:44 PM
lisa 23's Avatar
lisa 23
cheers for all help ive got it sparking now it was the resister that goes on the coil loom but car still wont start i have noticed that petrol is leaking out of the top of the fuel regulater seeping out of the pipe air pipe that goes directly on top of regulater this goes to the inlet manifold around where the air temp switch is any ideas on this fault??????????
cheers for all help so far peeps still
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
