gear linkage
Old Mar 27, 2006 | 12:09 PM
jimmylaud's Avatar
jimmylaud
Default gear linkage
hi guys just wondered if any of you guys know where i could get a new linkage from mines a bit like stirring soup cheers in advance
Old Mar 27, 2006 | 12:11 PM
SafeChav's Avatar
SafeChav
Just service it, the plastic parts wear, and theres a good mod you can do the joint by the gearbox aswell.
Old Apr 2, 2006 | 09:45 PM
fawdy's Avatar
fawdy
£250 for burton power quickshift. makes it miles better!
Old Apr 3, 2006 | 10:10 PM
Taylor's Avatar
Taylor
Aint that pricey for a new one
Old Apr 3, 2006 | 10:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Can you replace the plastic with metal washers to 'pack' it so to speak? or a thin washer either side of the plastic?
Old Apr 4, 2006 | 07:12 PM
SafeChav's Avatar
SafeChav
What plastic is that mate?
Old Apr 4, 2006 | 07:23 PM
vroooom ptssssh
It Wasnt Me!
I dunno I assumed their was some sort of plastic sleeves going over bolts that would wear either side that could be tightened up with washers? i remember someone mentioning you could replace them with washers but never looked at one myself to see what was meant
Old Apr 4, 2006 | 07:43 PM
SafeChav's Avatar
SafeChav
Ah ok. On the front of the linkage where the swivel joints are they have plastic flanged washers, theres a good mod you can do replacing them with 6x8 ball bearings, and 6mm steel rod. I think the plastic parts in the box the stick is in wear aswell though.
Jano jumped into a conversation and said using Puma internals is the same as a short shift but then wouldn't tell me what to change and advised me to get a puma linkage and compare the two helpful as always
Old Apr 4, 2006 | 08:15 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
hes alright that jano, bet you could have a right laff at his gaff!
proper gear selector,or should that be bo?
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
