2wd engine stripped NEW prices, dizzy+coils, injectors, rods
Old Mar 25, 2006 | 11:57 PM
Mr C's Avatar
Mr C
Default 2wd engine stripped NEW prices, dizzy+coils, injectors, rods
As above, Im breaking my 2wd 205blocked 330bhp engine so I will list all parts I can think I have for sale, some pics available, anything else you want that isnt listed then PM me and I will see what I have left Offers welcome, Im not asking silly money, just need to shift this lot ASAP:
USA IMPORT- poly bush rear diff mount SOLD!!!
4x 4x4 Dark Blue injectors £20
4x 803 Dark green injectors??? £100?
throttlebody £40
TPS £25
pair of std cams and pulleys £50
thermostat and housing £15
pair of alloy engine mounting arms £10
Distributor, with arm and cap £60
.48 ex housing £60
-31 actuator £30
T34 shaft and compressor housing only £320
fuel regulator £25
rear beam and pair of arms, ideal for modifying or re powder coating £40
50mm alloy dump valve Tpiece £10??
pair of front eccentric? adjustable strut mounts £60 improve that handling no end!!!
power steering pump £25
NEW YB0611 H.gasket £50 delivered!!
3x inlet valves £10 ea
enlarged plenum cover and elbow, de-burred inside and opened out to match gasket sizes on all faces for better flow.
2x2wd I/coolers welded together, same original high mounting position as a std cooler £100 cash (the silver one in the pic below)
Old Mar 26, 2006 | 12:28 AM
rauri's Avatar
rauri
up in smoke........
does the price of the actuator include postage?
Old Mar 27, 2006 | 07:29 AM
kev16v's Avatar
kev16v
hi m8
how much for the throttlebody an the Distributor, with arm and cap
cheers kev
Old Mar 28, 2006 | 08:12 PM
Mr C's Avatar
Mr C
PM sent Kev16v
Old Mar 28, 2006 | 09:20 PM
SPADGE's Avatar
SPADGE
Hi mate how much for the head gasket posted to MK?
Old Mar 29, 2006 | 06:19 AM
Taner's Avatar
Taner
Default Alternator
Hi Mate
How much are you after for the alternator. I can collect
Cheers Taner
Oh, and a price on the throttle body and TPS
CHeers
Old Mar 29, 2006 | 05:10 PM
Mr C's Avatar
Mr C
PMs sent
Old Apr 2, 2006 | 02:56 PM
turboloon's Avatar
turboloon
Default bump
bump for mr c i bught your calipers of you about 2 years ago for erst top bloke!!!
Old Apr 2, 2006 | 04:51 PM
anthony4773's Avatar
anthony4773
have you got the throttle position sensor and the air flow sensor?
Old Apr 4, 2006 | 08:39 PM
Mr C's Avatar
Mr C
PMs sent
Cheers for the kind words Turboloon Hows the project -escort wasnt it? done much??
Old Apr 4, 2006 | 09:28 PM
nik t's Avatar
nik t
Hi Mr C.
can you tell me if the top mounts are straight swap with standard ones.
(coil overs going on soon)
Old Apr 6, 2006 | 06:13 PM
Mr C's Avatar
Mr C
Pics of rear beam
trailing arms, note NO bushes
Old Apr 17, 2006 | 03:52 PM
James-W's Avatar
James-W
How much for the arms?
Old Apr 18, 2006 | 07:29 PM
Mr C's Avatar
Mr C
beam and arms £50 collected
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Toe Knee
Aug 23, 2015 08:31 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
