How does a diesel engine stop?
Old Mar 25, 2006 | 06:46 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Default How does a diesel engine stop?
Hi,
Does anyone know how a diesel engine stops as theres no electronics really like spark plugs etc?
Does it cut the power to the injection system?
Probably somthing simple...
Thanks
Old Mar 25, 2006 | 06:48 PM
graemewelch's Avatar
graemewelch
there is a solinoid on the diesel pump. it cuts the fuel off when you turn ignition off
Old Mar 25, 2006 | 07:08 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
yep fuel starvation
Old Mar 25, 2006 | 07:11 PM
SPADGE's Avatar
SPADGE
Just out of curiosity can anyone tell me exactly how a diesel engine works?
Old Mar 25, 2006 | 07:13 PM
cahzz's Avatar
cahzz
ive got a clio DCi 65 for a daily runabout im desperate to get more power out of it!!! does 70 mpg easy
Old Mar 25, 2006 | 07:14 PM
Jim Galbally's Avatar
Jim Galbally
www.howstuffworkd.com
really good description of how a derv engine works spadge
Old Mar 25, 2006 | 07:16 PM
Jamz's Avatar
Jamz
or even http://www.howstuffworks.com/
Old Mar 25, 2006 | 07:17 PM
Jim Galbally
m1ne r the l33t sp33k URL
Old Mar 25, 2006 | 07:18 PM
Disabled Account's Avatar
Disabled Account
OK Spadge, from memory it is something like this.....................
When a gas is compressed, its temperature rises, a diesel engine uses this property to ignite the fuel. Air is drawn into the cylinder of a diesel engine and compressed by the rising piston at a much higher compression ratio than for a spark-ignition engine, up to 25:1. The air temperature reaches 700–900°C, or 1300–1650 °F. At the top of the piston stroke, diesel fuel is injected into the combustion chamber at high pressure, through an atomising nozzle, mixing with the hot, high-pressure air. The resulting mixture ignites and burns very rapidly. This contained explosion causes the gas in the chamber to heat up rapidly, which increases its pressure, which in turn forces the piston downwards. The connecting rod transmits this motion to the crankshaft, which is forced to turn, delivering rotary power at the output end of the crankshaft. Scavenging (pushing the exhausted gas-charge out of the cylinder, and drawing in a fresh draught of air) of the engine is done either by ports or valves. To fully realize the capabilities of a diesel engine, use of a turbocharger to compress the intake air is necessary; use of an aftercooler/intercooler to cool the intake air after compression by the turbocharger further increases efficiency.
Old Mar 25, 2006 | 07:24 PM
SPADGE's Avatar
SPADGE
Nice one guys i now know something i have wondered about for years
Old Mar 25, 2006 | 07:41 PM
morto's Avatar
morto
when you think abit back diesel engines were abit of a joke but nowadays ther just as fast as petrol and more reliable and have loads more torque on top gear thay put up one of bmw new top diesel against the same power petrol and the diesel was nearly as fast around the track i think when the diesel turbo came a new bread of car was born, and no longer was a diesel slow , im looking at the focus tdci, and just to mention the diesel bmw thay put around the track was faster than the focus rs
andy
Old Mar 25, 2006 | 07:46 PM
GARETH T's Avatar
GARETH T
there sadly is a fundimantal problem with derv,,
IT BURNS SLOW
which means you cant get a derv too rev
Old Mar 25, 2006 | 07:59 PM
Twellsie's Avatar
Twellsie
has any one seen the derv Audi R8's in the LeMans series??? by far the fastest things on the track.
200 mph all day long sounds pretty good to me
Old Mar 25, 2006 | 08:01 PM
Thrush's Avatar
Thrush
Irritating c........
AROFL
j00d, 1337 sp33k L1ek OMfG, 1337 i5 teh s3x, lolz.... R j00 teh l-l4x0r? Lolz....
Old Apr 4, 2006 | 07:44 PM
Pez71's Avatar
Pez71
IT BURNS SLOW
Why do you need it to rev? If its got enough torque to pull a house down, you wont need all those extra revs. Low down grunt is what its all about, ask the Americans
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
taylora1409
Aug 12, 2015 12:06 PM
mattman1234
24
Aug 1, 2015 11:46 AM
