bigger brakes question
Old Mar 25, 2006 | 06:11 PM
16vzetec's Avatar
16vzetec
Default bigger brakes question
will i need a bigger master cylender coz i have fitted 300mm front brakes and sierra rear disc's to my mk4 escort??
all the mk4's i have seen with big brakes look like they have standard masters
Old Mar 25, 2006 | 07:48 PM
John Laverick's Avatar
John Laverick
Nope...standard master cylinder will be fine [Well it is on mine with 4 pots on the front and cossie calipers on the back]
Old Mar 25, 2006 | 07:51 PM
Paul17's Avatar
Paul17
wot 4 pots have you got mate on the front i'm gettin some 2wd cossie 4 pots on the way and i'm woundering what i need to do to get them on please?
Old Mar 26, 2006 | 05:28 PM
SafeChav's Avatar
SafeChav
Depends what your car was originally, and what size the master currently is....
Old Mar 26, 2006 | 06:41 PM
John Laverick
Mine are Brembo's...I didn't see your sig when I posted. You may actually need to upgrade the master cylinder to the RST one!
Old Mar 26, 2006 | 09:05 PM
adamS2RST's Avatar
adamS2RST
I run 300MM ST' front's and cossie rear's on my S2, no probs, standard MC.
Old Mar 26, 2006 | 09:07 PM
Paul17's Avatar
Paul17
sorry mate wot does standard ms mean? and wot are st brakes like to fit
Old Mar 27, 2006 | 08:57 AM
adamS2RST's Avatar
adamS2RST
Edit, hit the wrong key Master Cylinder.
Pretty straight forward afaik! But then I didn't fit them myself, got them fitted when Gadget removed my ABS at the same time
Old Mar 28, 2006 | 08:27 PM
slimwynn's Avatar
slimwynn
i'v got a 1.3 master cylinder would this work rs turbo callipers?
Old Mar 28, 2006 | 09:58 PM
SafeChav's Avatar
SafeChav
All the cars bar the Series 2 share the same Master Cylinder, it will run them, not very well though......
Old Mar 30, 2006 | 02:50 PM
paconassa's Avatar
paconassa
mk2 orion also had 25 MC I think....
Old Mar 30, 2006 | 03:43 PM
SafeChav's Avatar
SafeChav
I've heard that aswell but yet to see it...........i'm 99.9% sure the series 2's were the only cars that had 25's because they have the biggest brakes in the range.
Old Mar 30, 2006 | 06:36 PM
NUTS RuS's Avatar
NUTS RuS
Mk 1 early Orions ( 2 take offs not 4)
If your leaving the servo on you wont notice much difference as that takes up half the work for you
Old Mar 30, 2006 | 06:39 PM
SafeChav's Avatar
SafeChav
The only MK2 orions that have 2 take offs on the MC are the ABS ones?
Old Mar 30, 2006 | 06:46 PM
NUTS RuS's Avatar
NUTS RuS
A 1.3 Orion dosn't have ABS
Old Mar 30, 2006 | 06:55 PM
SafeChav's Avatar
SafeChav
Ok im confused now
I know a 1.3 Orion doesn't have ABS, have i missed something??
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
