Polly bushed rear beam.
Old Mar 25, 2006 | 04:54 PM
jazraymcbeath's Avatar
jazraymcbeath
Default Polly bushed rear beam.
I have just polly bushes the rear beam mount and am getting a bit of diff noise coming inside the car is this normal. It is as loud as a wheel bearing starting to go and sound like a gearbox bearing on its way out.
But prior to fitting the bushes there was no noise from the diff and i have not polly bushed the trailing arms.
I did not get any instructions with the bushes so when it came the rear beam i phoned around and they said the big cone bush replaced the original and then a donut type bush went on top with the largest hole pointing towards the bottom of the car. Has any one got instructions of these type of bushes to verify the top spacer bush is in the correct way.
Old Mar 25, 2006 | 06:06 PM
CosKev3's Avatar
CosKev3
Pretty sure thats wrong m8 if they are Deflex bushes you have used??????
If you look at the donut shaped bush the shaped bit on the one side of it is shaped to fit on top of the metal plate that bolts upto bottom of beam/shell
Old Mar 25, 2006 | 07:27 PM
jazraymcbeath
Thats what i thought but would like instructions to confirm.
Old Mar 25, 2006 | 09:53 PM
CosKev3's Avatar
CosKev3
Ring Deflex then
They don't supply instructions with the bushes,as you have found
Old Mar 26, 2006 | 08:37 PM
jazraymcbeath
Aye changed them over today took about 15mins a lot less diff noise and felt a bit better on the road. Thanks.
rex647
Mar 6, 2022 06:20 AM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
