Escort brake pipes...
Originally Posted by Iain Mac
Silly expensive from Ford if still available, but a 5 minute job for a garage to make them up.
Or you can buy the flaring tool, copper pipe and fittings and make your own.
With the car on the ramp access is easy.
Working on the floor, remove the old ones and use them as a template for the new ones away from the car. That way you are spending the minimum amount of time under the car.
