air injectors ( another mapping qs)
Old Mar 25, 2006 | 11:16 AM
Jay,'s Avatar
Jay,
Sponsor
Default air injectors ( another mapping qs)
one thing ive noticed when playing with boost settings is that even when the boost is set on a rpm and pwm based map the bosst will go up and down 1, 1.5 psi . Is this down to the amual valve having a littile trouble controling the preasure if so would i be able to stop this with air injectors
cheers jay
Old Mar 25, 2006 | 01:46 PM
Jay,'s Avatar
Jay,
Sponsor
bttt
Old Mar 25, 2006 | 06:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
afaik, wouldn't really be much different. even with air injectors, unless you have closed loop boost control, you are still running them on a map of rpm vs. pwm. they might be more consistent for a given temperature and boost level, but if the ambient changes i think that boost could still change with it. i'm no expert though, so would like to hear from others.
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
jay030787
Sep 25, 2015 01:38 AM
