IS MADROD's CAR DEAD---THE TRUTH
Well as far as TOTB3 is concerned almost, here's the saga.
The first trip in the car was to Zoo Motorsport & as soon as the car was started it was obvious there was a major exhaust blow.
Investigation on Monday last ,seemed to find the prob the fabricator had put a solid piece of metal , where Mark had asked for a flexi, it was wrapped so we didnt know. It went back & was all stripped down & corrected, the result it was just the same. A closer inspection reavealed the real prob, my mega bling manifold had all but broken in two, not cracked but broken.
We all agreed nothing we had done could have caused this, untill we remembered at the Dyno session in a desperate attempt to cut down on noise a silencer with a 10 foot extension was bolted to the wastegate flange & exit via the roof. maybe this caused it who Knows.
Today i took it back to the fabricator & we both agreed that in an effort to look mega bling design integrity & strength had been compromised.
Well it dont look bling anymore, the complete section near the wastegate has been changed & 3 large strengthening gussets welded in place.
Pictures have been taken & hopefully the design will be changed.
Got it back at 3-45pm today & Mark reassembled it & guess what prob solved. However it has lost us 2 days of progress & the car is far from finished. Tomorrow (friday) the car was due at Brunters ,but that aint going to happen. Mark has to finish off Leons Supra tomorrow morning & then straight back on mine ,Mark thinks it will be finished tomorrow, but i aint so sure & im sure work will be still going on Saturday, when Mark has also to finish off another compeditors car.
Said i would not run an untried car, but Mark will take all the his kit & finish it off on the day.
Believe me NEVER AGAIN & Mark has said the same.
Cheers Rod
Cheers Rod
Fook me you had me scared then ROD!!!!!!!!Hope it all goes well mate, im only got to TOTB to see your car go
Was going to Phone Mark today but i wont bother as i know he will be flat out trying to sort your cars out
PassionFords Creator
Fookin wounder Rod
So near yet so far away after all this effort.....
Just as a side note, It may be worth me mentioning that no passengers are allowed at Elvington as i hoped to finish TIB on "The Day" last year and it wasnt allowed.... Just in case you dont know that.
If i can help you or Mark in any way, please feel free to call me.
MADRod,
Stu I will be driving and mapping
wont let rod drive me
Lucky Autronic has top data logging
I will not be doing TOTB again unless the Car I am preparing to take is Finished 1 month before I am not going through this stress again.
Mark
Lucky Autronic has top data logging I will not be doing TOTB again unless the Car I am preparing to take is Finished 1 month before I am not going through this stress again.
Mark
Mark
Mark
Can i say we had a nasty, when i was driving once & since then Mark insists on doing the test driving , the wuss.
Rod
Mark
Mark
Hope lady lucks with you all the way on Sunday
Bet your are flat out sorting peeps cars out!! Never mind Mark will be all over after Sunday lol
will it fook
my pestering will start up
Mark
Mark
Rod
We hit a kerb sideways whjen he lost control on a roundabout trying to fooking show me how much better than Ayrton Senna he was
rod,mark and all the other competitors.
best of luck with the day lads,glad to hear things have worked out but sorry to see its all a late minute dash.takes a little bit of the fun out of it.
wish i was goin as i had planned to go with justin e.am in madrid at the mo and flyin home fri nite.last minute party booked for fathers birthday so cant miss that.
will try my best to get a flight in as justin has agreed to drive to an airport to collect me.fingers crossed as this is one horney day and the few cossies that are takin part are goin to be worth watchin.
have been away from the confuser so is spadge takin part now ???????????
Originally Posted by sunny
Did you get the tyres put on the wheels Rod?
Cheers Rod.
Originally Posted by Rob Virgo
rod ,
you lookin for 8" wheels or tyres.
rob
rob
Rod
Originally Posted by martin-reyland
rod, if you need any bits i.e. my manifold and w gate or anything... say the word. the cars in bits so its no problem
martin
martin
Then its finish off & tidy everything up. At the mo i have to join up wires to start the car
fingers crossed.
Rod
Rod,
I hope you make it for Sunday.
On a more sour note you'll find tubular manifolds on a cossie engine are basically a no go and getting the design right from a durability aspect is VERY difficult. All the best in getting it sorted though.
Normal guage tube is NOT strong enough.
Mine is now 6mm wall as 2mm lasted about as long as the first violent application of the throttle!!
Sorry to put a downer on it but that manifold will crack again in less time than it takes to say "Is it cracked again?".
. The manufacturer assures us its the first one to crack, probably means first today Can only wait & see, you never know may last all day Sunday
.Rod
Karl
So you say but I already have my own Manifold for the Evo 10k miles no problems,
However These are not sold on a production bases due to the possible problems with them,
With the advent of the Inturnal gated GT series turbo's almost makes these manifolds redunant for all but the maddest engines.
Mark
Mark
Mark the problem is with the design of the cossie engine, the resonance that the YB exhibits and the space in which we have to package the manifold. The downward angle of the exhaust ports makes expansion issues a serious issue on the YB, and makes slip joints a necessity.
I hope Rod's manifold lasts, truely I do but I know with all the heart ache and effort I've put into mine you're fighting a losing battle.
We are trying a new tubular design for my manifold,
So you say but I already have my own Manifold for the Evo 10k miles no problems.
Mark
Is it a tubular manifold and
does the evo make 600 + hp
Mark
Alq1k I wouldnt have said I have my own Design if it hadnt been Tubular, It makes 517hp 480ftlb thanks
, Now going to 550hp 500ftlb+ which makes a change of turbo needed so now a diff manifold,
But we are not here to discuss the merrits of diff types of manifold Rod was giving a progress report on his car after sadly wrong
reports of its demise.
Mark
reports of its demise.Mark
Nightmare
Thought it was gonna be another Cossie retirement
Well done for hanging in there
Can't wait to see the beast in action on Sunday, all being well with the car
