Headlinning
Old Mar 24, 2006 | 03:10 PM
Drjones's Avatar
Drjones
Default Headlinning
Hello
I have just got me old s2 back and the headlinning has been taken out so i have to fit a new one.
1. Can you still buy one from ford?
2. How the hell do you fit it!
Old Mar 24, 2006 | 04:49 PM
Would say they are no longer available from ford ,easy to fit ,at the rear there should be a metal locating rod which goes into a hole each side near the c pillar ,this is then rotated in the hole upwards,(make sure you are in a warm place to fit )then you will need some double sided tape(3m do some really strong stuff) put theis on the outside window apertures where the headling wraps round do the rear screen bit first then the sunroof and front screen then the sides ,checking all the time for creases ,when you are doing it you will know how easy it is
Old Mar 24, 2006 | 08:15 PM
Drjones's Avatar
Drjones
Sound mate will have to find one somwhere now the bars arnt there so will have to get them to DOH.
Any ideas??
Vincereese
Sep 18, 2015 12:48 PM
Vincereese
Sep 18, 2015 12:47 PM
Zetec_mk4_XR3i
Oct 16, 2004 10:49 AM
Zetec_mk4_XR3i
Oct 4, 2004 06:14 PM
