Smokey & The Bandit
Right my oil light came on, pump was knackered, when new pump was fitted and car was started the full workshop was full of bluey white smoke.
After about 1.5 mins the engine chugs and dies unless you keep the revs up, if you rev it high where the turbo should come in, my boost gauge never goes above 0 psi! I've been told it could be valve stem seals and piston rings OR that the turbo seals are away. Any ideas cause its driving me mad
the turbo wont boost up unless your engine is under load mate so reving it wont make it come on boost, well possibly 2psi max!,
you need to drive it to see where the boost comes in, should be 2900 rpm if its a standard t3 and exhaust housing,
the smoke will be causeed by either
1, fooked stem seals, (VERY fooked)wont smoke alot on boost but will on over run. and massively when you start!
2, piston rings, smokes hard on and of boost if they are proper fooked!
3, turbo rear oil seal, leaking it into the exhaust housing, is worse just as you come on boost then it clears, and on over run is smokey
could be a combination of all three mate, good luck
Originally Posted by s1_turbo
Just checked, backbox is full of oil
What does this mean?
On the plus side your exhaust won't rust
I don't know how your planning on taking exhaust manifold off and letting the turbo hang there.......
If theres oil in the exhaust, undo the manifold and pull it forward and stick your fingers in the ports and feel for oil, if theres none, it has to be the turbo. Also have you ever started a car with no manifold, its fucking well loud
I agree, and so would my neighbours, was fun until i gave it a rev and flames came out
Ran ok with manifold off so i presume its the turbo. Wheres the best place for a new one?
u crazy c*nt
Depends what your after really, i re-built mine. But yours to be fair is probably more shagged than the local hooker on a weekend.
danvisteon
59
Aug 25, 2004 08:58 PM
unchballs:
