spark plugs & HT leads
rite cant afford new engine anymore so
i just gonna treat mine to a service & new standard cam
i haven't replaced the plugs in at least 2 years, think i should change them? also what plugs should i go for?
think i have champion in it at the mo
what about HT leads, is it worth buying a new set of them too?
CheeRS
CheeRS
cheers for input adam
spec is
16psi, GRS, ahmed bayjoo chip, zorst, engine internals standard
for HT leads, just the usual standard ford ones or these blue motorsport ones?
spec is
Fit his lot and you will be fine
Plugs - NGK BCR8ES
Leads - Ford or Magnecor
rotor arm - Ford
Distributor cap - Ford
Fuel filter - Ford
Oil - Mobil 1 Motorsport
Oil filter - Ford
Then the car will be runing perfectly
Plugs - NGK BCR8ES
rotor arm - Ford
Fuel filter - Ford
Oil filter - Ford
do you get a feeling of Da ja vous davie?
sure we've discused this! lol
will do mate,
is there any point in change the dissy n rotor arm n stuff? do they wear n hamper performance?
Originally Posted by T28 RST
Ive been using a set of Magnecor 8.5mm leads for 4 years without any problems at all
rang ford, they said they dont have any motorsport ones listed
they will not as its not in micocat
ditto
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
