Special hose wanted
The heating system is now removed from my Escos.
The normal set up is, a rubber hose from the water pump via a steel pipe through the bulkhead to the heater matrix. The return comes back through the bulkhead and via a hose to the engine.
I need a special hose to connect from the end of the metal pipe directly to the engine return point. Anybody done this before?
cheers
cheers
