REMANUFACTURED 5th Gear for the T5
Rapid Ford is in the process of having 5th gear remade to make rebuilding the T5 2wd Cosworth box a little easier.
Price is not yet comfirmed but don't be shy to show your interest. I'm not gonna
if you change your mind
If you're interested let me know and I'll put your name on the list for the first batch.
The first batch will be a group buy at a discounted rate.
Daniel
Daniel
Hi
yup the company that I'm using does short run work for cosworth. they will be cut as the original.
if you've got a rumbling box rebuild it instead of buying a secondhand one.
cheers
Daniel
cheers
Daniel
just the single 5th drive gear (the one that is bastard tight on the splines and a sod to get a puller behind so you chip the ends off the teeth), or the driven as well to make a matched pair?
roughly how much?
good idea
roughly how much?
good idea
I've spoken to the company and they have told me that the 5th Gear is a ground cut gear and the drive gear is an industrial shite one, so I will probably be producing both - maybe along with a few other gears as well
Should have a price within a few days...
The Youth.
Sep 30, 2015 09:59 PM
