question rst
have just got my engine fueling set up by my garge and it saying on my boost gauge 18psi on standerd ecu ihave a chip that iwant to fit but will it need setting up again or not
also have a 31 actuator that was set up when the engine was dynoed with thechip that iwant to fit
iwant to fit the chip but will it be safe or not with out the set up or just stick with the stander ecu
ps why its saying 18psi + is my gauge f**Kee
Firstly if the ECU is standard it won't run '18psi', as said once the chip is fitted you'll need a setup. If the boost gauge is sayin 18psi on a std ECU then yeah its fucked or something wrong
chears boyzz ithough itl need a set up istay with the standerd ecu my gauge must be shit as it cost over Ł60 ill try onther gauge cheeeeeeeeeerrrrrrrrrrrrrssssssssssss
ps ill let you lot know what the prob was and ihope she dont go
BANG
BANG
