PP8's
Old Mar 19, 2006 | 09:43 PM
Rick's Avatar
Rick
Default PP8's
What's the issue with this plug at high power levels? is it reliabily (ie melting electrodes) or missfire problems?
Rick.
Old Mar 19, 2006 | 10:10 PM
abdr500's Avatar
abdr500
its more heat range and melting point
Old Mar 19, 2006 | 10:46 PM
Billabong's Avatar
Billabong
As above, if heat range is wrong for the engine, then the tips melt, which could = disaster.
They're a good plug when used in the right application.
Old Mar 20, 2006 | 08:11 AM
Turbo lag's Avatar
Turbo lag
I think Stage three is the most they can do, anymore and you risk the tip melting off and scrapping your engine
I would avoid and try the Ford apr 701's
Dave.
PS These are RS turbo plugs and cost less than a tenner, as recommended by Mike Rainbum.
plynchy
16
Jun 27, 2012 08:08 AM
rugged rick
Jun 17, 2008 12:00 PM
gwynny
Oct 18, 2007 03:47 PM
Neil S
21
Jul 2, 2005 06:18 PM
Ragtop
Jun 18, 2004 10:24 AM
