What are the differences between 350bhp and 400bhp rebuilds?
Old Jul 29, 2004 | 06:34 AM
smokey's Avatar
smokey
Default What are the differences between 350bhp and 400bhp rebuilds?
What are the differences between 350bhp and 400bhp rebuilds that accounts to £3-4k more for 400bhp?
What do you actually get for your money?
Old Jul 29, 2004 | 06:50 AM
User 32922's Avatar
User 32922
50bhp
sorry fella, will wait for someone with sense and knowledge to answer
Old Jul 29, 2004 | 06:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i guess a ported head is involved, and the time taken to do it accounts for a lot of money.
Old Jul 29, 2004 | 07:03 AM
©hatter Box's Avatar
©hatter Box
big injetors for a start ur have to go to greys for 400bhp and better head work and bigger turbo for 400bhp pectel will all ways help u better for running that bhp
Old Jul 29, 2004 | 07:54 AM
smokey's Avatar
smokey
Originally Posted by pgtips
50bhp
The 50bhp is irelevant. Its the cost!
Old Jul 29, 2004 | 07:55 AM
Matt's Avatar
Matt
a lot of money
Old Jul 29, 2004 | 09:47 AM
3drstretch's Avatar
3drstretch
I think you need Better items in the build to handle 400 bhp reliably.Which also means more expensive.You probably could do a 400 bhp motor for not much more than a 350 BUT you'd be asking ALOT more of the cheaper parts you put into the build which would eventually BREAK.then your back at square 1.You may be lucky and get away with it BUT i would rather do it ONCE and do it Properly.
For Example
Head Gasket.
Grp 'A' would probably be ok for 350 About £80
For 400 i would go for a Proper WRC 4 layer one £350 As your running more boost etc.
Do that kind of thing to say 5 items and see where i'm going.
HTH
Old Jul 29, 2004 | 09:49 AM
low comp t4 greys 2bar - 400bhp
or low comp head work / cams / t34-t38 2.3 bar / greys
Takes ya pick LOL
Old Jul 29, 2004 | 10:33 AM
smokey's Avatar
smokey
But which one is cheaper?
Old Jul 29, 2004 | 11:03 AM
swerv's Avatar
swerv
i dont understand why people say 'do it once do it right' as you know you wont be doing it once anyway
you can have 350 quite sensibly on a standard engine , you cant with 400
Old Jul 29, 2004 | 11:06 AM
Spiky's Avatar
Spiky
i have 350
std comp, grp a head gasket.. t34 21 psi
for me to go to 400 i'd need soooooo much more boost, head ported, fuel pump, greys, live map
more bits too, like diff bigger brakes,,lol
350 is VERY reliable at my spec, an to just get the extra 50bhp, i personally dont think it's worth it
Old Jul 29, 2004 | 11:09 AM
3drstretch's Avatar
3drstretch
Yes it is Spiky and You Knows It.
Old Jul 29, 2004 | 12:46 PM
smokey's Avatar
smokey
Originally Posted by Spiky
i have 350
Can you get a little bit more on std comp but using light blues?
Old Jul 29, 2004 | 12:50 PM
CabrioTurbo's Avatar
CabrioTurbo
if your going for 400Bhp then why not round it up to 500 having said that you may as well go for 600........
Old Jul 29, 2004 | 02:30 PM
Spiky's Avatar
Spiky
i have 350
yes u can, as u can run about 26psi, live mapped will give more power
Old Jul 29, 2004 | 02:31 PM
Spiky's Avatar
Spiky
ummmmmmm no
i aint payin 6k+ for 50 bhp and less oil consumption
Old Jul 29, 2004 | 02:39 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not sure what you're saying here spiky, as light blues don't flow as much as greys
Old Jul 29, 2004 | 02:40 PM
Spiky's Avatar
Spiky
light blues WILL run 26psi held
any highter then u will need greys
Old Jul 29, 2004 | 02:50 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i get you. sorry, i thought you were already running greys from your ealier post but now i realise that you are saying to get 400 you'd need to go to greys.
so you're on dark greens and 21 psi?
Old Jul 29, 2004 | 02:51 PM
Spiky's Avatar
Spiky
i am yes
Old Jul 29, 2004 | 03:20 PM
TIFF's Avatar
TIFF
Chasing Radders
I am running about 360-370bhp on a standard engine with greys and a T34
Old Jul 29, 2004 | 03:35 PM
Rhys's Avatar
Rhys
IMO i wouldnt have gone 400bhp as 330-50bhp is great. Only reason i am going that is my engine had to have a rebuild anyway so why not?
Old Jul 29, 2004 | 03:56 PM
swerv's Avatar
swerv
Tiff can i ask why you went greys and not light blues??
Old Jul 29, 2004 | 05:13 PM
Spiky's Avatar
Spiky
swerv, the light blues he had were faulty
Old Jul 29, 2004 | 05:49 PM
Matt's Avatar
Matt
spiky, the difference between your setup and a 400 build on the road is devastating, tim has a scs "greens" (4*4 bottom end, 2wd std head, std cams, t34, 500 cooler) engine holding about 22psi and compared to mine his feels like 75% throttle lol it also runs out of revs sooo fast its silly go blag a ride in lanky's motor (identical to mine apart from the extra 50kg of cheese his carries around ROFLOL) and then come back and report
one thing i will say for a 330 conversion is they have loads more traction over a 400 one
Old Jul 29, 2004 | 05:53 PM
RichardPON's Avatar
RichardPON
Get better tyres then you pikey bast!
Old Jul 29, 2004 | 06:04 PM
Matt's Avatar
Matt
rich, when i drove tims car it was running my old 3 door rims with its quality nankang specials that chop bought still on and it still had more traction than my car on 235 proper rubber my car span 5th gear up with them on
Old Jul 29, 2004 | 06:05 PM
Fagin's Avatar
Fagin
Better tyres and proper geometry and suspension will put paid to that gimpy!!!
Marco has a well set-up car and he can floor it through the gears from 1st without wheelspinning.
RichardPON's Avatar
RichardPON
What's your definition of proper rubber then?
Old Jul 29, 2004 | 06:13 PM
Fagin's Avatar
Fagin
MATES ribbed for Matt!
Old Jul 29, 2004 | 06:14 PM
Matt's Avatar
Matt
yes shaun i know that, mine has got better with a few mods since it last ran 15's, sitting the tyres as flat to the road as poss was a place to start and also stopping it bottoming out. marco's car is the danglies BUT it must have as much cash in its handling as youve spent with tony
rich, aint saying im a tyre expert by any means mate but i know that the £30 a corner nankangs aint a patch on the continental sport rears i now have. (waits for you to say they are shit lol) it launched very well indeed and gripped quite well last time i dare launch it
Old Jul 29, 2004 | 06:19 PM
RichardPON's Avatar
RichardPON
Not too bad a tyre at all.
Must be the driver at fault then
Old Jul 29, 2004 | 06:25 PM
Matt's Avatar
Matt
either that or the loads more powerful engine and steep agressive torque delivery having a slight effect
RichardPON's Avatar
RichardPON
Nah, driver
Old Jul 29, 2004 | 06:31 PM
Jim Green's Avatar
Jim Green
DAMNED GOOD TOPIC....
Lets see some technical answers by the tuners/Engine Builders.
Old Jul 29, 2004 | 06:45 PM
Fagin's Avatar
Fagin
Now you KNOW that could NEVER be true!!!!
The car is back at TS filling up Tony's bumbag as I type!
Old Jul 29, 2004 | 08:21 PM
marco polo's Avatar
marco polo
Matt
i haven't spent that much on the chassis,i would say in total about 3k thats front/rear/supension/beam/arms/ tca/rose joints/castor/camber and setting up
and don't forget i have a proper L.S.D which does help
I can make the car wheels spin in nearly every gear but theres no point..i just feather the power with my right foot depending
i use the normal GD3's which are ok ...
all my car needs now is just a little more power to finish it off.but untill i come into some money it's not going to happen , once this engine is dead it will take me over a yr to re do it ...if it was to fail tobe honest i wouldn't be that bothered as it has lasted ages to be fair... i have done 8/9 trackdays and it's still fine no smoke or nothing
power isn't everything it the whole car thats the key... brakes ,supension,handling,tyres
if you have these 4 things you nearly have a good car
well thats MHO of coruse
Marco
Old Jul 29, 2004 | 08:27 PM
DazC's Avatar
DazC
Pectel what? T2/T6/T6M/T10 yes but the shonky old Pectel Weber Marrelli boards are hardly worth a ham shank!!
Just to clear that up.
Old Jul 29, 2004 | 08:33 PM
Switch's Avatar
Switch
so a low comp engine, about 7.2:1 with 200 block whats the best way from here to achieve 380+bhp??? (would like 400)
T34 63 degree housing and greys and wrc headgasket? If so what kinda boost???
DazC's Avatar
DazC
Just another note on the subject...
The cost of the 400bhp conversion is directly proportionate to the sum of the parts that break around it......and also how you want the 400bhp to perform/response/ etc....you can buld 400bhp to be torquey as fook low down/ mid range or you can have it top end for track etc. Ther are a lot of variables..
