Gabat escort cosworth 4sale 580 hp
Hillclimb ford escort cosworth 4sale
It's runs a standard displacement 2 liter yb block.
The engine is good for 580 hp but it can be tuned upto 730 hp and a torque figure of 627 nm.
And it's has only run 4 km.
It's a new car.
Some more specs in german.
5 Gang sequentielles Getriebe
3 Scheiben Kupplung
3 Spezialsperren
Bilstein Gr. A Fahrwerk einstellbar (höhenverstellbar vorne und hinten
3" Auspuffanlage
Gewicht 1.054 kg
Sicherheitstank mit Catchsystem
6 Punkt H-Gurt 3"
Schalensitz
4 x Alu mit Yokohama als Transport und Lagerräder
4 x 250er Avon Slick auf Leichtbaufelgen
Karosserie komplett nachgeschweißt
http://members.aon.at/gabat-tuning/startfahrz.htm
Originally Posted by Dan
Pete.W I know, stunning arnt they!
Not over the top IMO either!
Not over the top IMO either! translated the spec for those interested ..
5 gears sequentielles transmissions
3 disks coupling
3 special barriers
Bilstein Gr. A load work adjustably (height adjustable ahead and behind
3" exhaust concern
weights 1,054 kg of security tank with Catchsystem 6
points H-belts
3" scarves seat
4 xs Alu with Yokohama as a carrier and warehouse wheels 4 xs 250er Avon Slick
on easy building rims car body completely nachgeschweißt
Enter one of totb and you scare some slyline evo's and impreza's.
But you need fit a larger fuel cell.
One the sister cars of this escort has run a topspeed of 329 km/h that's faster than a ferrari f40.
And i believe that the white i posted has a very topspeed of 330 km/h+
their some fucking fast cossie's outside the uk sweden and norway.
Cosworth is still best.
Originally Posted by trevcannon
Originally Posted by Freddy_mercury_magic
Originally Posted by RS500
why's it got spunk on it
Sorry!
Some more specs in german. i've put proper english translation alongside
5 Gang sequentielles Getriebe 5 speed sequential gearbox
3 Scheiben Kupplung triple plate clutch
3 Spezialsperren ?
Bilstein Gr. A Fahrwerk einstellbar (höhenverstellbar vorne und hinten height adjustable suspension front and back, i.e. adjustable bilstein coilovers
3" Auspuffanlage 3" exhaust system
Gewicht 1.054 kg weight
Sicherheitstank mit Catchsystem Safety fuel tank, with catch tank system
6 Punkt H-Gurt 3" 6 point 3" harnesses
Schalensitz Shell type bucket seats
4 x Alu mit Yokohama als Transport und Lagerräder alloys with Yoko's for transport and paddock wheels
4 x 250er Avon Slick auf Leichtbaufelgen 4 x avon slicks on lightweight alloys
Karosserie komplett nachgeschweißt fully seam welded shell
3 Spezialsperren ?
What power are these Escort's that are hitting 320Kph/200+mph?
I think it's from germany or austria.
and it's imperial blue
It's got a pectel ecu and the engine is stroked to 2,3 liter and the engine is good for 620 hp at 7500 rpm and torque figure of 672 nm modefied gearbox ratio for more topspeed and diff is also modded for more topspeed and 0-100 km/h in 3,5 seconds.
btw the gearbox is 6 speed whit longer final driver ratio.
Here is the final drive for gearbox and diff.
Gearbox ratio 0.87 / Diff 3.14.
Found a picture or two of it it's the cossie in the center.
This the 329 km/h one.
I got the 329 km/h figure i don't if the owner has reach that speed.
The Gabat Cossies are from Austria. I saw them running when I was at the Mickhausen hillclimb event near Munich last year.
http://www.autoclips.net/events_inside.php?event=8
check out nr 18.
You can find more videos of them if you search some sites from Germany, Austria, Switzerland. try mega hillclimb links.
check out nr 18.
That cossie is fast i have hear that some of the gabat escort's run engines whit 800 hp these days.
Is this true??
Found a new video of one of the gabat escort's this time a wrc version.
http://www.autoclips.net/detail.php?id_video=2231
Is this true??
Guest
Posts: n/a
Picture of YUM in the left corner, thats when l went to Holland Show
Originally Posted by Muzz
Id fuck Vanessa Feltz & Mo Molem at the same time and sell my story to get the money to own that car
You must really want one of those cars to do that
