Which fans
Old Mar 18, 2006 | 08:57 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Default Which fans
Am unsure of what to buy, so thought I'd ask people who would know..even tho this has prob been asked a few times already
For my custom radiator, I require 2x 8" fans. One sucking, one blowing plus any fixing kits.
These are the options I have found:
Links not neccessarily where I would buy them from, more for spec info.
SPAL £120 for a pair inc fitting & delivery from Fereday. £50-ish each (fan only) from other places
Over all diameter = 210mm
Blade diameter = 190mm
Thickness in centre = 52mm
Thickness at outer edge= 32mm
Max Air flow 436.00 cfm
http://www.feredaycars.co.uk/everything%20else/
KENLOWE Sucker/Blower £80 approx each
Over all diameter = 184/210mm
Blade diameter = 178/202mm
Thickness in centre = 59/59mm
Thickness at outer edge= 36/38mm
Max Air flow 380 cfm (typical car rad) 590 cfm (free airflow)
http://www.kenlowe.com/fans/consumers/fans11.html
Davies Craig £50 approx each
Over all diameter = 213mm
Blade diameter = 186mm
Thickness at outer edge= 31mm
Max Air flow 400 cfm
http://www.mawsolutions.com/documents/dcsl8spec.PDF
So, ideas on which YOU consider the best option..or link to another type/ manufacturer please.
Old Mar 18, 2006 | 09:55 AM
DazC's Avatar
DazC
If the others are rated at air flow in free air then I would get the Kenlowe.
The HD Kenlowe fans that were on my Dad's car were absolutely awesome! Cooled the car down far quicker than the current Spal fans.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
