alternator info wanted 2wd & 4wd
Old Mar 17, 2006 | 11:13 PM
thedaddie's Avatar
thedaddie
Default alternator info wanted 2wd & 4wd
couple of questions for 2wd and 4wd please
what ampage is your alternator?
what type of pulley is on the alternator, V belt or 6 ribbed?
Old Mar 18, 2006 | 10:00 AM
CosKev3's Avatar
CosKev3
Pretty sure they are both 90 amp on 2wd and 4x4 saphs,due to heated screen etc
2wd have the twin v-belt pulley,4x4 have the multi ribbed type
Old Mar 18, 2006 | 10:25 AM
nicksaph's Avatar
nicksaph
mate, mine has got the twin vee belt arrangement and my mates has got the multi ribbed belt.
mine has no air con, and his has so i would assume that if the car is fitted with air con it has the multi ribbed belt. unless some one can correct me.
Old Mar 18, 2006 | 10:35 AM
CosKev3's Avatar
CosKev3
My 4x4 on a 1990 H reg with no air con had the multi ribbed belt
Old Mar 18, 2006 | 11:54 AM
KSA-Cossie's Avatar
KSA-Cossie
My 93 k plate has no air con and has the multi ribbed belt,when i replaced my alternator last month bosch said they only come with the twin v pulley now .
Old Mar 18, 2006 | 05:46 PM
thedaddie's Avatar
thedaddie
do you know the bosch part no. for the 90 amp alternator?
Old Mar 18, 2006 | 07:47 PM
KSA-Cossie's Avatar
KSA-Cossie
Will have a look tomorrow for you buddy.
moesin2005
Jan 23, 2022 06:28 PM
155lee
Aug 14, 2015 11:21 AM
Harryh24
Aug 11, 2015 07:48 PM
adriansaleem
Aug 3, 2015 11:21 AM
lockie
Jul 31, 2015 10:03 PM
