4x4 i/c into 2wd saph??
Old Jul 28, 2004 | 06:00 PM
Benn 304R's Avatar
Benn 304R
Default 4x4 i/c into 2wd saph??
Does this work?
Im sure it does but my birds dad is having some problems.
I thought it would be a straight forard swap but turns out it isnt.
Is there a correct procedure to install the 4x4 cooler?
cheers
BENN
Old Jul 28, 2004 | 06:12 PM
rapidcossie's Avatar
rapidcossie
i will be fitting a 4x4 cooler to my car next week and also thought it would be a simple swap... any help would be great!
Old Jul 28, 2004 | 07:05 PM
cossie1's Avatar
cossie1
I would have thought it would be a simple swap of the cooler itself, but might need to use 4x4 hoses ?
Old Jul 28, 2004 | 07:19 PM
Alvyn's Avatar
Alvyn
u have to fold down the lugs on the top of the 2w/d rad and cut the boost pipe thats on the drivers side JOB done also DOES help if you undo the bolts that hold the rad in place so that it can swivvel a bit!
Old Jul 28, 2004 | 09:17 PM
Benn 304R's Avatar
Benn 304R
cool, so thats all that needs to be done then.
Old Jul 28, 2004 | 09:19 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
buy longer bolts,makes life alot easlier
well i did,cos the rad sure wasnt going back up without them
Old Jul 28, 2004 | 09:22 PM
Switch's Avatar
Switch
and if ya fit the rad back not straight make sure it aint tilted backwards or your top rad hose will catch on the power steering pulley and u will spill your engines coolant all over the floor
Benn 304R's Avatar
Benn 304R
cheers guys
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
