FITTING SPARCO STRUT BRACE???
Ive just got a sparco strut brace for my s2erst have any of u any ideas how to mount it to the strut tops.... is it ok to use beefy selftapping bolts?? as i dont fancy stripping all the suspension struts out to bolt it in
...cheers again peeps
cool.
get some stainless self tappers then. drill a small pilot hole the raise the torque on the drill and power em in level. heater box might want a bit of persuasion tho, most do. just get a mate to lean on it while you put the first screw in each side.
i drilled and tapped mine,
drill the holes with an 5 mm drill bit, then get a 6mm tap and thread the whole, dont need to strip suspension for this
using self tappers will make the brace usuless and just a cosmetic add on
do it properly mate,you only have to drop the strut down a bit. undo the top bolt and will come enough to get your hand up in there
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
jack it up ,drop the strut down a bit,mark ,drill,bolt,simple!,otherwise,you should have made one out of plummers plastic pipe and chrome painted it,
dyou know how much flex is in that there chassis?
mines getting some soon,when i get paid enough.
any pics of the helper? maybe the guy in the other thread could pay you for them
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
) won it for £33.50 btw
