Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
one cosworth exhaust valve
Old Mar 14, 2006 | 05:38 PM
markk's Avatar
markk
Default one cosworth exhaust valve
as above i need one exhaust valve please !
Old Mar 14, 2006 | 08:19 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
If you don't mind second-hand, I'll have a look in the garage. They were replaced after my cambelt lost a couple of teeth, and I replaced all 16 valves regardless. This means they may not be 100% true, and probably not much help. But I could post them to you and let you decide.
Alternatively, Andyescos off here was selling a complete set of valves and guides at rock bottom price.
Look here https://passionford.com/forum/viewtopic.php?t=163057
His last comment on 15th Jan was "sod it, Valves and guides, £250". Might be gone by now - worth a try ?
Old Mar 14, 2006 | 08:23 PM
markk's Avatar
markk
cheers for the offer, if you roll them on the bench you can see if there straight or not pretty acuratly. if there is by any chance one straight, im more than willing to pay you for it.
many thanks
mark
Old Mar 15, 2006 | 08:21 AM
frog's Avatar
frog
many thanks
mark
I'll have a look tonight
Also PM'd andyescos, he's not on here too often though.
Old Mar 15, 2006 | 05:15 PM
frog's Avatar
frog
markk, got one that seems to roll ok. Well it does to my untrained eyes
The others are well beyond repair though.
The one that looks ok has carbon deposits chipped off the bottom of the stem which suggests it has had contact, but rolling it doesn't show massive movement.
Happy to post to you if you pm me an address, then take it from there. If you like it, you keep it, if you don't - bin it
If you decide to keep it, it will need a clean though as is it covered in deposits.
Up to you
Old Mar 16, 2006 | 08:59 AM
frog's Avatar
frog
It's in the post - should be with you tomorrow
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
jdsjojo
Aug 1, 2015 08:50 PM
Old ford
Jul 31, 2015 06:50 AM
