rust eater thingie
Old Mar 14, 2006 | 11:54 AM
davidnormanuk's Avatar
davidnormanuk
Default rust eater thingie
does this stuff work?
http://www.frost.co.uk/item_Detail.asp?productID=8298
Old Mar 14, 2006 | 12:19 PM
Moondust_crust's Avatar
Moondust_crust
yes but this stuff is better.
http://www.frost.co.uk/item_Detail.asp?productID=8293
Old Mar 14, 2006 | 12:24 PM
dexterc's Avatar
dexterc
So how does it work then? Scuse my ignorance.
Old Mar 14, 2006 | 01:02 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
But don't think you can pour it into your Battery-tray and Sunroof Cavity and suddenly have a concours RST!!
Old Mar 14, 2006 | 01:47 PM
dexterc's Avatar
dexterc
You mean it doesnt eat rust, replace it with new metal and repaint it? Dayum, my hopes have been dashed.
Old Mar 14, 2006 | 02:27 PM
davidnormanuk
I thought I'd found something to go with mith my magic plastercine.
Old Mar 14, 2006 | 04:44 PM
Moondust_crust
it will eat rust to an extent, if you want to get rid of it completly weld new metal in. its good stuff which i rate highly but its no miracle worker.
cheers mark.
Old Mar 14, 2006 | 05:07 PM
dexterc's Avatar
dexterc
So if youve got small surface rust patches, this would be a decent product to use on them?
Old Mar 14, 2006 | 06:13 PM
Moondust_crust
aye, but i would grind them down first then apply.
Old Mar 14, 2006 | 11:04 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
i did as above with the inside of my roof skin then gave it three coats of POR 15 (available from frost) it is top stuff they use it in the marine industry, it seals any rusted area permanently and actually gets harder in damp areas, it says on the tin "avoid contact with skin as only time will remove it, our permanent means permanent", ive still got some specles on my arm from three months ago!!! this is some serious shit and i cant recommend it enough!!!!
Old Mar 15, 2006 | 12:02 AM
SafeChav's Avatar
SafeChav
cheers mark.
Agreed, to be honest if your looking to get rid of rust the only true way to do it is to remove the entire panel, which isn't always possible.
Rust forms in very thin and long lines well before it ever comes to light a panel has rust in it, if its something like a wing or a quarter then it can usually be salvaged but once rust has set into structural items like chassis rails you are fighting a losing battle, you may delay things but it will inevitably rot away sometime.
The Preverbial "Metal Cancer"
Old Mar 15, 2006 | 08:30 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
tek it your getting the 5 litres then
Old Mar 15, 2006 | 08:31 PM
SafeChav's Avatar
SafeChav
Hows your car running No rust preventer on the planet that can save my car
Old Mar 15, 2006 | 08:58 PM
akito-man's Avatar
akito-man
its not, im buying some wheels to fit to an industrial size barrell of granville heavy duty rust cure.
at least its lighter if its half eaten with rust,fook that carbon fibre shite,no soul i tell thee ,no soul.
Nov 1, 2015 06:53 PM
