Pro Alloys s2 Turbo coolant cooler...
Old Mar 13, 2006 | 05:36 PM
Manchester Mike's Avatar
Manchester Mike
Default Pro Alloys s2 Turbo coolant cooler...
Anybody run one?
How much does it help water temps??
I have the 1st generation pro alloy intercooler with a recent new ford rad.
Are the turbo coolant coolers still £100?? Mike.
Old Mar 13, 2006 | 05:41 PM
320 bhp's Avatar
320 bhp
i had 1 on mine made a bit of differance but not a lot
Old Mar 13, 2006 | 06:18 PM
James Raby's Avatar
James Raby
I liked it, it did help, but to be honest - you probably dont need it
get some water wetter from ebay, cheap as chips
Old Mar 13, 2006 | 06:54 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
James, are you a rep for Water Wetter?? You seem to love the stuff.
Old Mar 13, 2006 | 07:03 PM
©hatter Box's Avatar
©hatter Box
thats crap worst 10 pounds i ever spent
Old Mar 13, 2006 | 07:10 PM
Rick's Avatar
Rick
header tank cap.
thermostat.
Old Mar 13, 2006 | 07:12 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Put ice in the header tank every morning
Old Mar 13, 2006 | 07:19 PM
James Raby's Avatar
James Raby
Christian, it worked for mine mate
Also it ain't a tenner, it's £5 on ebay
Alex, why you say it was crap?
Old Mar 13, 2006 | 07:48 PM
Christian and Beccy
#1 in Spelling Club
James, is it really a fiver on Ebay??
Is that the proper stuff then?
Old Mar 13, 2006 | 07:59 PM
James Raby's Avatar
James Raby
http://cgi.ebay.co.uk/Red-Line-WATER...temZ8046141633
Old Mar 13, 2006 | 09:49 PM
ivorbiggun's Avatar
ivorbiggun
Sounds like the 'flux capacitor' to me
Old Mar 13, 2006 | 09:50 PM
ivorbiggun's Avatar
ivorbiggun
P.S. don't let ANYONE tell you the ACE Cafe was good tonite cos it wasn't.
Old Mar 13, 2006 | 09:51 PM
James Raby's Avatar
James Raby
You what?!
Old Mar 14, 2006 | 02:39 PM
Linsay's Avatar
Linsay
Mike, water temps on mine are ok since fitting the GRS and new ford rad but we're still in the depths of winter, think it will need the spal fans am gonna have on soon tho in summer
I also have a thermostat from Christian which opens at 82 degrees i think?? or something, might help??
Old Mar 14, 2006 | 02:42 PM
James Raby's Avatar
James Raby
you want the kenlowe fans, 2 x 10in ones to go between rad and cooler
Old Mar 14, 2006 | 02:47 PM
Linsay's Avatar
Linsay
Thanks for asking James, but no thanks
Having Spal ones, almost had an incident with the one Kenlowe i have - that nut on the front is a bit dangerous
Old Mar 14, 2006 | 02:53 PM
Rick's Avatar
Rick
the blades fell off the spal ones i had
meant to be ok though.
BTW, Mike hasn't got water temp issues - it's all in his head
Old Mar 14, 2006 | 03:04 PM
Linsay's Avatar
Linsay
Oh heck hope that doesn't happen Nightdavva recommended them as well as others
Old Mar 14, 2006 | 03:07 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I use Spal heavy duty fans. Do the job fine
Old Mar 14, 2006 | 03:57 PM
Sexy-RS's Avatar
Sexy-RS
Water wetter made no difference to my temps
Old Mar 14, 2006 | 04:01 PM
James Raby's Avatar
James Raby
What mix or water/antifreeze did you have when adding it?
Old Mar 14, 2006 | 04:06 PM
Sexy-RS's Avatar
Sexy-RS
You can't mix antifreeze with it iirc?
Old Mar 14, 2006 | 04:08 PM
James Raby's Avatar
James Raby
it doesn't say you can't use antifreeze with it, only gives you guidelines for mixes for RACING purposes
I had 50/50 mix and added the whole bottle of water wetter, done the job lovely
It did make a difference to mine, 110% over and over prooven to matey's at Norfolk meet cos it used to get rather hot, but was fine with the additive
Old Mar 14, 2006 | 04:13 PM
Sexy-RS's Avatar
Sexy-RS
Alex emailed them as it never said if you could and they said it should only be added to water
You should make your own mix and start knocking it out if it works lol! As water wetter did definatly not work in both our cars
Old Mar 14, 2006 | 07:10 PM
Rick's Avatar
Rick
Water wetter will NOT make a difference to the TEMPERATURE of an engine, if the thermostat is working correctly. Thats not what it's supposed to do. And a low reading temp gauge does not always mean things are good. I run a 92 stat in the winter.
Old Mar 14, 2006 | 07:18 PM
James Raby's Avatar
James Raby
after discussion with someone else about this thread
I mean to say
The temps did not rise silly high on the gauge, when water wetter was added it sustained a 'normal' peak temp instead of rising so high it became a worry
Old Mar 14, 2006 | 07:25 PM
Rallyesport's Avatar
Rallyesport
I'm fitting a non-turbo mk4 radiator, with my IC setup I think I can make room. I'm also pluging the turbo water on the in-side of the radiator.
Old Mar 14, 2006 | 07:28 PM
James Raby's Avatar
James Raby
Good idea that if you can get it to fit
Massive size difference, how are you going to 'T' in the water from turbo?
Old Mar 14, 2006 | 08:26 PM
Rick's Avatar
Rick
I'm not 100% sure, but aren't the cores thinner on these?
Old Mar 14, 2006 | 08:35 PM
shane's Avatar
shane
ive got twin fans a GRS and an alloy rad but more cooling is always needed...so is water wetter anygood.a guy told me about it once i thought he was windin me up!
Old Mar 14, 2006 | 08:39 PM
Manchester Mike
Thanks for the comments
Don't have any temp problems as yet.... but it is FREEZING outside at the mo!!
I have an 82 degrees stat but just hate the way the intercooler blocks all of the rad, and just worried it may cause issue's in the summer.
Think i'll definatly be taking the 2 fans that come with the pro alloy cooler off it and putting them directly onto the rad and will just wait for summer to see how the temps go from there
Old Mar 14, 2006 | 10:15 PM
zippyobrien's Avatar
zippyobrien
dude, i thought about this, so i kept the radiator of my transit when it blew up, might need to mod the car slightly to get it on, but its huge!!!!!!
thicker core to.
any thoughts any one?
Old Mar 14, 2006 | 11:16 PM
Tony Turbo's Avatar
Tony Turbo
Default Re: Pro Alloys s2 Turbo coolant cooler...
Originally Posted by Manchester Mike
Anybody run one?
I run one, did make a noticab;e differencne. I wouldnl like to get abigger made at some point, or maybe I'll fit another, I jusy don't know at the moment thohugh.
Kiss:
Old Mar 15, 2006 | 07:19 AM
Rallyesport
Drilling a hole in the plastic tank and screw in a hose barb with som glue. I was planning to do this in the tank where the water enters the radiator so no water will go uncooled into the engine.
Old Mar 15, 2006 | 06:32 PM
Wazzzer's Avatar
Wazzzer
would it be useful for my chargecooler?
Old Mar 15, 2006 | 07:00 PM
Rick's Avatar
Rick
yes mate, if u plumb it into the charegecooler circuit.
Old Mar 15, 2006 | 08:37 PM
Wazzzer's Avatar
Wazzzer
sorry Rick I meant the water wetter
Old Mar 15, 2006 | 09:03 PM
Rick's Avatar
Rick
lol, yes mate it will
Old Mar 15, 2006 | 09:29 PM
Rallyesport
What water wetter does is to make the water more "wet" so the water covers more surface. This will transfer more heat from the metal and to the water and from the water through the radiator and to the air. Can be used with only water since it inhibbits corrosion and with water and anti freeze. Water has better cooling properties than anti freeze, so pure water and water wetter will be the best option when there is no chance of the water freezing. This is what I use in the summer.
SmudgerByName
52
Jul 28, 2016 06:14 PM
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
Matt Baxter
Sep 16, 2015 08:30 PM
muffster
Aug 17, 2015 08:17 PM
Escortdriver1
Aug 13, 2015 05:55 PM
