Air Leak
Hi on my S1 I have noticed there is an air leak coming from between the break master cylinder and the break servo. From what I understand there is a seal between the two parts, but Ford no longer list the part. What can I use, or do, as there car will no longer idle correctly.
Please help.
Thanks
Please help.
Thanks
Had same problem too mate only way was to get 1 new is buy a whole new brake servo kit and fook that they wanted loads
i just went and got a good condition 1 off a car in scrappy....if not you could use the rubber band thats on your side reapeters as it do same job
i just went and got a good condition 1 off a car in scrappy....if not you could use the rubber band thats on your side reapeters as it do same job Thread
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
