SOLD!!!!!!!!!
..done around 5k...no in and out play in shaft...360 bearing....works rear exhaust housing (you can see where the EGT sensor plugs have been welded up)...restrictor on it but as you can see its derestricted...great stage 3 turbo.
No actuator included....Has std 2wd cosworth metal water pipes and banjos.
325.00 UK pounds delivered.
Not really mate, MR.C wants £440 for his, i just sold one there to and i had put it up for offers, the best i got offered was £250, altho i`d say yours would be worth a bit more as mine had a couple of marks to the blades, by all means this still didnt hamper any perfomance altho it did seem to put a few peeps of,
Good luck anyway
Good luck anyway
too expensive , if it hadnt been tampered with i.e the holes welded and the intake milled out it would be worth what you want. for me to be able to re-use that i would have to have another restrictor made up.
155lee
Oct 24, 2015 11:11 AM
