coolant warning lights - DAMAGE LIST NOW INCLUDED !
its a sad day for my motorsporting hobby
ive managed to lose my first ever engine today at the lookout stages in yorkshire. only managed to get 1/2 way round the first stage when i realised something was amiss.
i have all the relevant guages to tell me about the motor, but to be completely honoust, when the stages are slippy, you pay more attention to applying best part of 300 horses to the rear wheels and keeping it on the straight and narrow.
first thing i saw a whisp of something through the bonnet vent, car felt ok, nothing immediatly amiss, so carried on ................flat out. next thing car feels flat, and through the extremely effective peltor intercom system i could just here a very very faint rattling noise.
then i knew something was amiss
slowed right down and glanssed at the oil pressure - ok, oil temp - just a touch warmer than i would have liked on a fookin freezing snowing yorkshire morning at 09.20hrs 150deg
- but why
checked the water temp, off the fookin scale and touching the stop for a second lap
so , no compression ona few cylinders, a rattling crankshaft + the bits we cant see
now , with hind sight ( great thing really
) as with my oil pressure warning light ( large fook off amber lamp below 22psi) , i should have a large fook off what colour here lamp to early warn me of over temp
so a cheapo early warning system today has cost me , a cosworth engine, an entry fee, and travelling costs.
sponsor forms will be available direct from me via pm
moral of the story .......... dont rely on guages for fault prognosis
Originally Posted by Ryan
sorry to hear this mark
any idea what caused it?
tottally agree about the guage thing, i.e if you've got time to look at them whilst your driving, your not driving quick enough
onward and upwards tho, now ive no excuse for making it 4wd ( apart from the money) and maybe a little more power ( fook knows how tho-was too fookin fast as it was for 2wd)
PassionFords Creator
Sorry to read this Mark. I feel your pain mate.
Kenny and I will look after you with costs where humanly possible mate as i hope you know.
Wounder.
Wounder.
Originally Posted by DazC
Sorry to hear that Mark. I know you really liked that engine as well.....
Ideally you need a coolant level and a coolant temp sensor warning sytem....
if it rises about 90 it comes on
Wounder.
Wounder.
im going to get the lump out next week, and probably just rebuild it as it was, cause it was a fookin scorcher of a motor. just got to make it 4wd in the meantime !
Originally Posted by Tony Ryan
Sorry mate , kicks you in the bollox when you least expect it . Just remember the smiles tho , only a small set back !
but will be fitting a coolant light ! !
sorry to hear this mark.
a warning light sounds like a good idea, but couldn't something also be done in the ecu? for example, there is a modifier for the ignition based on coolant temp. couldn't that be used so that when coolant temp is higher than normal limits, ignition advance is changed to drastically reduce the power available? that would have the 2 fold effect that you feel it when driving, and if the power produced is less, less heat will be produced.
don't know if that's a good idea, maybe worth talking through with stu? at least a loss of power could allow you to limp to the end of the stage without suffering major damage.
that does sound like a pukka i dea, its done with intake air temp, so why not with coolant temp
i will have a chat !!
cheers
I have a warning light on my water....100degree's it goes off at....
Fan switch failed and this what made me slow down...
If you can't rely on the gauges surely u could smell the heat of the water ?
Ecu can be set to retard the spark if water becomes too hot, but that just heats the water more due to less energy being transfered to the crank instead, thus the same fuel energy is wasted into the water jacket.
As you rally drivers will know, on a traction limited stage you may not feel a loss of say, 20% actual torque and thus the engine could be being damaged further by your not noticing.
Could always add far bigger injectors then we can do something with the fuel side of things instead, but at way over 9:1 and with 40psi, there isnt much fuel left to fooking add on the current setup....
A temperature related light on the dash is the way forward IMO.
sorry to hear this.
what about a secs monitor.
fitted mine today and it has a light on it to show you of any faults.
the paramitors can be pre-set so if the alarm light ( or buzzere if fitted) it will go off.
but i have to say that with the rebuild , im more than happy ( and will be ) with the compression being even higher, as we havent reached the pinnacle i dont think of the high boost high comp motor. in fact i know full well there is alot more scope in raised compression if i was to go to carless fuels. but even with optimax i feel a little more is still available.
sorry to hear this.
but the facsility would be a great advantage - and would have indded saved my motor
simon ................................. the challenge is set. i need a standalone adjustable temp warning device to trigger an early warning device !
Sorry to hear this.
My worries are a little diff from urs. I'm stupid enough to put 2 bar through a CVH, and rely on it for every day use. I am screwed if i dont have a car. I have warning lights/buzzers for oil temp/pressure, water temp/pressure, boost and afr. Its no failsafe, but will go some way to saving an engine. The water temp has saved me a couple of times in the last 7 yrs of having the car
Good luck in getting it sorted
so the engine is now out, and the damage that is visible, is as follows,
headgasket blown between numbers 2 and 3, block cracked in number one, one exhaust valve bent in number 3
any ideas as to why the exhaust valve bent ??? and only one of them.
will be getting the head tested tomorrow. hopefully the valve didnt stay open due to a build up of water behind it
Sorry to here that Mark...talk about gutting.
Would it not be possible to have all your guages wired to an auxiliary lamp in the dash.
If the lamp lights you or your nav then know to check your guages to establish where the issue lies.
Whatever hopefully you'll get your engine sorted soonish.
Really sorry to hear this
and for your information, the Defi's come with this facility built in. Not only does it have a warning light built into the gauge, it has a high pitched whistling "buzzer" to notify you. However, I doubt you would hear this on a rally stage (as it is just audible on a track day), but the extra thing it has is the ability to connect a remote warning light as well, which can be mounted anywhere you like.
http://www.defi-shop.com/product/op/op_ind2.html
It has two different coloured LEDs, so one could be oil temp or pressure and the other water temp
Really gutted to hear this.
The SPAs are the same with a negative earth tigger so you can trigger a waring light/buzzer cut the ignition, pump etc etc
cheers guys, i have to say looking at these guages they are quite expensive to buy, and alot of them look like fancy toys, but, there not quite as expensive as the engine ive just scrapped
a warning system is now being developed as we speak for the coolant overheat system.
cheers
mark
cheers
mark
Mark,
They are very good gauges with stepper motors etc. I wouldn't use any other type - they have proved their worth on LOADS of occasions, and as you said, would have saved your engine (but hindsight is an exact science
Onwards and upwards
) Onwards and upwards
