Final Engine Pics and FAO Karl
Ok the finished engine...
Karl...just looked at the plugs after a 30mile run and the rim is black but the center is whitish....i know i am running in and not thrashing it..but is that right?I am guessing i am running a good lean AFR economy....Cant check the AFR till tuesday when i get the tail pipe pole.....
Originally Posted by Pete.W
what power is it then? or is that still to find out.
what is the black box just above the air filter held onto the wheel arch?
...in theory power could hit around 520bhp according to Karl
..all that from a 7.9-1 comp engine
The car drives unbeleivable...much better than any other map i have used its just perfect IMO
I aint brown nosing but to have an off the shelf chip thats 95% there on 1000cc injectors and the rest of my spec is astonishing
Originally Posted by Bosch-Man
...not got that far lol..only done 55miles!.....Just comparing how long a tenner lasts compared with the escos on greys and the old saff stage 3...and its better.
when Karl mapped my car on greys it was better economy than the greens i'm running in my new car.
be a good car when all run in Phil.
[quote="dave cos4x4"]
Same here Dave
mines better economy on Greys
...not got that far lol..only done 55miles!.....Just comparing how long a tenner lasts compared with the escos on greys and the old saff stage 3...and its better.[/quote
Just to back track......My T38 engine on greys and breifly on S8 and 8 greens
...Done 2000miles and deceided i wanted to do a GT35 engine
To this....
Run it for a few miles and decided to break it up...but kept the engine/head...
Now a T4 engine...i hope i dont change my mind again...mind you its only a turbo swap now and the swedish plenum...i even have the Norris map for that configaration too
To this....
phil, did you chop the plugs straight after a full load run, or did you pull em outafter it'd been left to idle fo a few secs? as the condition of the plug tells you nothing abou the AFR if its been left to idle
also why are you waiting for a tailpip probe for your LC1? do you know you can use it to replace the std lambda? so you could put it in the stock location (as long as it doesnt hit >1300*C )
Weld a boss in the downpipe not use a tailpipe probe, you get a far more accurate reading, and a more recent one too.
Tailpipe is a real bodge by comparison, even more so on a ameteur sensor that isnt aware of tail winds like Stu's fancy one.
I like it
. Bring it to Bruntingthorpe for the TOTB qualifying day
.Would be a good advertising tool for your bosch motorsport business phil
Go for it, be good to see some fresh faces running at TOTB
Spiky its on very loosely...its just a support
You would be better off without it.
When the engine rocks you want that pipe to move with the engine, not stay in place relative to the car.
If you must supoprt it for some reason, make a bracket that comes off the rocker cover or something.
...chip if you read i said LOOSELY which means i have taken into account engine movement
and imo is satisfactory....also the tail pipe thing for the LM1 is patented and a very special design having seen it i have no fear of using it...thanks for your concern though.
